Engine Mount Help!!
Old Jan 7, 2006 | 04:27 PM
Miloman5's Avatar
Engine Mount Help!!
So after looking at my engine and realizing that its moving WAYYY too much I see that my engine mount is broken.... Now i just need some feedbak on how to install the new one!!
Thanks....
Old Jan 7, 2006 | 04:38 PM
typeR's Avatar
which mount
Old Jan 7, 2006 | 11:14 PM
Miloman5's Avatar
The Front one.....not the mount by the belts
Old Jan 8, 2006 | 07:30 AM
typeR's Avatar
theres also one by the transmission and behind the engine by the firewall...anyway ...you'll have to remove the cruise controler motor by the side mount to give yoo access to the side mount...if your side mount wasnt blown you could get away with just taking out the bolt that connects the mount to the egine...but im certain its blown ....it is the reason most people loose the front mount...so anyway take it out...then loosen all 5 bolts on the front mountuse a very long extension and a breaker bar ....then jack the engine alittle remove the top bolt from the front mount ,and once you get the motor to clear the shaft remove the four remaining bolts...the mount can be removed from up top,no need to get under the car ...unless it's vaccuum line doesnt just come loose....replace the new mount by threading the top bolt back in a few turns...the engine will not want to lower exactly where it came up from and it will take some coaxing to get it to line back up....a large screw driver may come in handy here...examine the side mount and fill it with window weld...including the lower part that is /was liquid filled and probablly ruptured....i would allow it to dry over night...
Old Jan 8, 2006 | 12:08 PM
johntypes's Avatar
My mount broke last year I had 44000 miles cost me 240.00 out of warrenty
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
