Engine Differences btw CL-P CL-S
Old Oct 2, 2002 | 05:59 PM
2001CL's Avatar
Ricky: Drugs > Football
Does anyone know what the difference in the type s engine that account for the 35 hp. I was wondering if there was anything i could change or do to narrow the gap. I'm not talking about headers, intake etc cause i am going to do those too. Thanks.
Old Oct 2, 2002 | 06:08 PM
TheModMole's Avatar
13 Second CLS Defender :)
Uhmmmnnn...
Type S vs Premium
Dual stage induction vs Single intake plenum
Compression Ratio 10.5:1 vs 9.8:1
redline 6900rpm vs 6300rpm
Old Oct 2, 2002 | 06:10 PM
hotelniko14's Avatar
only way narrow the GAP : UR pulleys, Header and CAI...
and your right there.
and even comptech sc
Old Oct 2, 2002 | 06:15 PM
NJTypeS's Avatar
For the amount of $ you spend on comptech headers UR pullies and a CAI plus installation, it would have cost the same to get a type s
Old Oct 2, 2002 | 06:18 PM
2001CL's Avatar
i meant narrow the gap in the engine, change some things in their. Not the things that both cars can do like headers, s/c, ur pulleys.
Old Oct 2, 2002 | 06:22 PM
TheModMole's Avatar
read my reply... thats all of em..... suspensions are modified as well but that has no effect on horsepower (at the engine)
Old Oct 2, 2002 | 06:29 PM
2001CL's Avatar
Has anyone done those changes, thanks TheModMole.
Old Oct 2, 2002 | 06:32 PM
TheModMole's Avatar
Not that I know of.... The compression upgrade costs would be pretty damn steep for an engine pull... at that point you might as well do a 3.5Litre upgrade..... and im not sure how much hp just the manifold swap would give you at 9.8:1 (considering youd need to get the imrc solenoids and wire the harness to the ecu as well) .. In all NOT WORTH the trouble ! trust me
Old Oct 2, 2002 | 06:40 PM
gmilian's Avatar
Red X
i don't think anyone exactly answered you question. the engines are the same. the type-s makes more hp by the intake.
Old Oct 2, 2002 | 06:42 PM
TheModMole's Avatar
Well not to bust balls... BUT the intake is peanuts compared to the increase in compression
Old Oct 2, 2002 | 06:47 PM
one way trade in for a type-s
Old Oct 2, 2002 | 06:53 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Hmmmm....seems you all forgot about that cam they installed on the type-S...
The intake accounts for the torque bump and at a much lower rpm and for a longer time.
The compression helps it overall, but combine this with what is essentially a mild street cam for the Type-S...and you get the extra 35 ponies....also probably the optimized timing combined to give it a bit more as well...
Old Oct 2, 2002 | 06:56 PM
TheModMole's Avatar
Uhmmnn no not really there sport... same cams in both
Old Oct 2, 2002 | 07:00 PM
really...same duration and lift on both....
Old Oct 2, 2002 | 07:02 PM
TheModMole's Avatar
Moom, yes they are both exactle the same
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Dec 13, 2015 02:21 PM
01CLOwner
Oct 9, 2015 01:07 PM
Iakonafuji
Sep 21, 2015 02:39 PM
