EMERGENCY-help stock sway bar
Joisey Commuter
I've run into a problem disconnecting the stock sway bar. One side was fine, but the other side just spins. Is there a trick, other than the allen wrench on the end that isn't working.
Thanks!
Thanks!
first off, u shouldve payed 75 bucks for parkave acura to do it for u. its so annoying. i did mine already.
get a ALLEN KEY and a open wrench. place the allen key inside the hole in the screw to hold it from moving then turn with the wrench. have a friend help you. i stripped my hole where the allen key goes and i had to pay for new bearings. it was a bitch.
why are u removing the sways. dont do that
for the rear, remove the long bar, then 1 bolt for the shock and maybe if u have to the plate next to the bolt. by removing 2 screws. i had to cuz i couldnt align it right.
for the front. remove the bolts on the bottom(2 of them) then on top remove the 5 screws.
Joisey Commuter
For the rear you must undo the sway link to the "axle" in order to remove the strut assembly. I eventually got it undone using your method (it's what I was already doing, but I hoped there was another way). It added about 75 minutes to the job (2.5 hours total for rear, 2 hours front).
Thanks for your help. Tein SS are installed and the car is LOW. Have to work on raising it back up a bit tomorrow night.
Dragging knees in
Originally Posted by Pure Adrenaline
I don't think you have to undo the sway bar link to get the strut assembly out.
you dont even have to touch the sways when removing the shock/strut assembley
IMHO just put everything back to normal and call around a shop that will do it for $150
now some may disagree but spring install is no way a easy install and if you have never done it and dont have the tools to expidite the install it could possibly take you all day to do it!
it was a bitch when i started to so i said fuck it and took it to a shop, paid $180 went out to eat with my friend came back 3 hours later and the car looked awesome!
sidemarker
Joisey Commuter
Well, I don't know how I could get the strut assembly out without removing that link. Believe me, I tried for about 15 min and it wasn't coming out. As soon as I got it undone, I slipped it out and went on my merry way. Really quite easy once the link was moved out of the way.
Dragging knees in
Some people don't think removing the STB is necessary when doing the rear bank header, but I found it a lot easier with it off the car, with a lot more room to maneuver in.
Whatever the method, as long as the project gets done right, it's all good. We all come here to share information and make things easier for others, and we're just telling you that it wasn't absolutely necessary to remove the links to get the strut assembly out. That's all.
Joisey Commuter
No matter to me one way or the other. Deed is done and all is well. Wish I could've figured it out without undoing that damn link, but I guess I just didn't have the imagination to get it. I'll have the air tools before the sway install tho!
Thanks for all the help everyone.
Sway bar questions
Guys i have 2 questions
1st- It is easy to install sway bars yourself ? ( if not how much it will cost ?)
2nd-Do i need to make aligment after that ? I just replaced shocks and spring along with aligment now i gonna put sways on . Should i go for aligm . one more time ? Thanks!
Love you all I did the same set as Distin Today .........i can't even tell .the difference is so big . I always used Bilsteins in my cars . They are simply the best ! Is someone still thinking what shocks to get , my answer is Bilsteins . I will post some pics later .
Thank you guys for all advices .
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
