electric turbo/supercharging CLS
#41
BTW, being a Centrifugal design a bypass is not need but welcome. The bypass is not for bypassing air for low load cruising but for preventing compressor surge, boost backing out the compressor when the throttle is closed.
If a centrifugal design is used then air will flow by at low loads but will be restricted. So low speed mileage is reduced but top end power is gained.
#42
Happy CL-S Pilot
The good news about this TurboDyne is that IHI has licensed the technology and will make TurboPac.. the bad news is that this Co is bone dry... no cash... so unless garret would licensce the tech and produce those TuroPac... it would a dying tech,...
One saver is the low cost Turbo Air... an ELectric Turbo in your CAI pipe...
#43
Happy CL-S Pilot
Unless... when Turbo is "off" it would boost 0 bar... but still spinning to ensure 1bar... that is it the electric motor is still spinning at low current to keep the pressure to 1 bar.
#44
I have a turbo charged car and it does not take a few seconds to spin up. No it is not instantaneous and it is a small turbo a k03. It takes like 1 sec and just down shift and your golden. Also, all the turbos that I have seen run of exhaust gas and they have been built to work that way for a reason. I would love to see a cl turbocharged! but u would need to beef up the tranny
#45
Moderator Alumnus
Nice VW b.t.w.
#47
Moderator Alumnus
Originally posted by yjack
Any update??
Any update??
I have been on contact with a turbodyne sales rep. I've been trying to see if I can bring the $ down. Still $1400 at the moment. Soon as I'm settled into my new place in January I'll order the unit and install it. Along with some new tires
Figure during a month or two of talking he can persaude me to purchase it at a lower $
Also, after reading the comptech installation manual for the supercharger. I do believe I'm going to buy some additional goodies to tweak the unit.
Soon as I place the order in the next month or so, I'll post some pics of the unit...
EDIT:
I will also take the video cam to the local dyno place when I go. My CLS is in need of a O2 sensor now (pretty rough idle). So I'll get all of the little BS fixed before I dyno it.
#48
go like hell
1 Post
I'm personally not digging it cause you gotta put HUGE Alternator and a Huge battery(i'm talking like a semi battery) in CL-S(which equals more weight). and that's provided you don't have any major system. Plus with a Electric supercharger. when you "nail it" lets say it's 9 o clock at night and you got on your headlights on. and your bumping to you system. your lights will fad out and your music will cut out. they can say it will work on only a 12 volt battery but that's fine if you have nothing else running. To me If i had the money for a Supercharger I'd wait on the Jackson Racing S/C which someone suppose to be working on. I think that will be cheaper than the C/T
#49
Moderator Alumnus
And a true 1000CCA battery would cover it for about $80.... Which is what I plan to do.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
