eibach sways not impressed
Old 06-29-2004, 03:52 PM
  #41
Dragging knees in
Pure Adrenaline's Avatar
AuCLSman --
Could you elaborate on "balancing" the endlinks? Are you talking where to place the endlink on the sway bar, since the bolt holes on the sway bar are longer than the bolts themselves??
Old 06-29-2004, 04:28 PM
  #42
AuCLSman's Avatar
P/A, yes&no, i'm refering to the notations in the comtech install guide which states that after connection of the links to the sways the links should be positioned in the same relationship to the adjacent suspension components then the interior brackets tightened to specs (the effect of this is to balance or center the sways between the left and right side components. if memory serves , the comtech guide specified the link should be adjusted to be parallel on each side. the slotted bolt holes in the ends of the sways help to allow for this adjustment
Old 06-29-2004, 04:37 PM
  #43
AuCLSman's Avatar
P/A, now that i'm thinking on it, the slotted holes are provided on the interior connection brackets (brackets which house the plastic bushings) this slotting allows for the final adjustment i noted in the prior post
Old 06-29-2004, 08:07 PM
  #44
Best D-Line in the NFL
Amoeba's Avatar
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Went driving hard as fuck today...I do notice a little less body roll and I can take turns harder without squeals...one of my fav turns I get about 10mph faster and I think the conti's soft sidewall is holding me back....the sways are a bit of improvement but not day and night
Old 06-29-2004, 11:24 PM
  #45
///M POWER
darrinb's Avatar
i'd still double check on the install
Old 06-29-2004, 11:35 PM
  #46
Amoeba's Avatar
The install feels pretty locked in there tight, and the bolts are on there pretty good..
Old 06-30-2004, 05:36 AM
  #47
bullaculla's Avatar
I know what happened!!!
they probably just painted your stock bars red:P
I installed mine myself, here are some pics so you can compare bars. look at the difference in size
rear
front bar is same diameter, but the stock bar is hollow.
Old 06-30-2004, 07:44 AM
  #48
Amoeba's Avatar
Thats how mine looked
Old 06-30-2004, 07:55 AM
  #49
fuzzy02CLS's Avatar
"balancing the links"
I never heard of that one.
The CT instructions say nothing of that...
http://www.comptechusa.com/instructions/ins026.pdf
Old 06-30-2004, 01:31 PM
  #50
AuCLSman's Avatar
fuzzy02cls, i used the comptech install instructions along w/ the factory manual. re: my comment "balancing or centering" and end link alignment of the rear bar, i'll check on this aspect this weekend i'm sure there is specific language about this, perhaps in the factor guide.
Old 06-30-2004, 01:47 PM
  #51
Not Asian
phipark's Avatar
I can feel mine. Only at higher speeds though. Once I get new tires I should really be able to tell a difference.
Old 06-30-2004, 03:49 PM
  #52
dgracer's Avatar
Originally Posted by thescoundrel
You should try a rear lower tie bar. It's cheap ($30) and it is very noticeable on cornering.
I have to admit that I cant see why a tie bar would do anything on our cars. Looking at the build of the stock cross bar it is hard to believe that there would be much flex being cured by one of these. The stock piece looks beefier than the $30 tie bar does. Looks maybe....
Old 06-30-2004, 09:18 PM
  #53
Amoeba's Avatar
Okay I was wrong, now after having the sways for a few days I do feel the difference....damn on the onramp for the turnpike it felt sooo much better...sorry for this thread, it can be deleted now
Old 06-30-2004, 10:33 PM
  #54
///M POWER
darrinb's Avatar
omg man, u are a drama queen
Old 07-01-2004, 03:25 AM
  #55
bullaculla's Avatar
good to hear!
emailnatec
29
09-28-2018 04:27 PM
CL-S progression 01
01-26-2016 04:15 PM
steve
09-30-2015 09:23 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
Quick Reply: eibach sways not impressed
