Eibach Pro kit. Camber correction?
Old Nov 10, 2001 | 03:05 PM
mackdaddy's Avatar
Prolly asked a million times before, but came up with squat doing a search. It's a toss up between Comptech / Eibach, and leaning towards Eibach if I don't need to do camber correction. A little negative camber won't hurt anyway.
Pics (or links) would be nice also.
On a side note, installed the Comptech sways this morning. What a difference!!!!!!!!!!!!! Glad I took everyone's advice, this is the way the car should come off the assembly line. NO TWO WAYS ABOUT IT!
FYI for the sway install process. Use a pair of small needle nose vise grips, and 1/2" drive ratchet with a 14mm short socket (14mm long for the fronts.) You hold the stud with the vise grips between the sway / endlink (yes, there's enough room.) This is the easiest way to do the job. Makes it a breeze.
Still busted the back of my left hand quite nicely!
TIA - Jim
Old Nov 10, 2001 | 03:18 PM
mackdaddy's Avatar
Ok, I'll answer my own question (just looked at Chod's FAQ.)
I'll stick with Comptech
Q - anyone running Comptech / Tokico Blue's? Sounds like the stock dampers will need replaced anyway.
Still give me some pic links for Comptech's. Although I've seen them a million times, I wan't MORE!!
Jim
Old Nov 10, 2001 | 05:04 PM
mackdaddy's Avatar
Ahh, ta heck with it. Just ordered Comptech springs from Tim.
I'll let the stock dampers do their stuff for a while first.
Old Nov 10, 2001 | 09:34 PM
SinnedTL's Avatar
Ain't No Other...
you should change out your shocks too, it gives the car ten times more feel and it gives your car a nice firm ride (not harsh), check out my sig, I have the tokico blues on my ground control coilovers...my GC are lowered about 2 finger gap all around and the shocks blew out after about 2 weeks since I put my GC coilovers on...
Old Nov 11, 2001 | 07:27 AM
CO-CL-S's Avatar
Do you always talk to yourself? I guess Sat. afternoons are a little slow on the board. My guess would be that Koni yellow is the strut of choice here. I seem to remember 1/2 front and 3/8 rear for initial settings? YMMV
Old Nov 11, 2001 | 08:44 AM
Mike's Avatar
I have the comptech springs for over a year and haven't had a problem w/the shocks. i'll replace them when they wear out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
