dry ice icebox?
Not Fast Enough
dry ice icebox?
I was at the track this weekend and was running 14.6's 85deg. I know that warmer air gives less horsepower, but what if i put dry ice into the icebox (by the cone filter) wouldn't that drop the temp of the incoming air, and another question would the extra CO2 (dryice i think) would it mess up the sensors to give less power
another question is when i was shifting i was not letting off the gas at all and when i hit 3rd and 4th i hird a little chirp i think its the belt slipping, but i checked the belt and it was really tight??
any input of comments are appreciated
thanks guys!
thanks guys!
If you attach a small bar refrigerator inside the engine compartment with the icebox sealed inside you'll be better off. Just run all the ducts through the side of the refrigerator and seal. Make sure you can open the door to change the filter. I had to customize the hinges for this application. Power can handled through a converter.
I saw a guy spray N20 on the intercooler in his Vette to cool down incoming air. He gained like 80+ horsepower if i remember correctly. Note, this was not a N20 shot - he was just using it to freeze the intercooler.
Not Fast Enough
jt
i was launching at about 1500 but i slipped the clutch not dumped, that way it bearly spins all the way through first my 60ft was 2.29 on stock tires 22psi i am still trying to perfect the launch, but these cars are hard to launch
Originally posted by ModAddict
It might have been CO2 spray, not N2O. http://www.designengineering.com/cry...r_sprayer.html
Happy CL-S Pilot
who has the CryoGenic Intake form Design Engineering?
http://www.designengineering.com/cry...ir_intake.html
Here is the PR with Dyno: http://www.karbelt.com/newsletter/20...ei_release.pdf
i can't find the price on that cryogenic intake at any of the listed dealers. anybody know how much it is?
Originally posted by SLY1TYPES
so if that cryogenic thing works then putting a small block of dryice in the icebox box would work then right?
did anyone read the question about the belt slipping on shifts 2-3 and 3-4?
any input would be appreciated
kevin
kevin
Not Fast Enough
kevin
kevin
A block of dry ice in your intake would probably not be a good idea. Sure, you're cooling off the air that's going into the engine, but you're also reducing the amount of oxygen thats going in - dry ice is solid CO2. If you want to try something like this, you'll need to figure out some way to vent the CO2 gas coming off of the dry ice.
SidhuSaaB
05-30-2020 12:40 AM
Nitin
09-30-2015 08:22 PM
