Driving Lights
Driving Lights
Hello guys, I know this question probably has been asked many times, but, does anyone have a quick and easy way to replace the driving light bulbs? Does one need to find a hydraulic lift to use? The instructions in the owners manual are clear, but getting the housing out takes some thought.
Thanks ahead of time!
Not Asian
Were you serious about the hydrolic lift? It takes about 7 min. with just a phillips screwdriver. There's a screw that you need to access from the inside of the grill. Do a search.
Here's some old pics I took bak in 2000:
http://home.nc.rr.com/raleigh5o/Unscrewing_Lamp.jpg
http://home.nc.rr.com/raleigh5o/LampSwingOut.jpg
Hope this helps.
Hope this helps.
thanks guys, i have the PIAA'S ready to go, but the owners manual said to do it from underneath, which is next to impossible for a non mechanical car guy like myself!
Did u see my pics? Takes less than 2 minutes.
Not Asian
Originally Posted by ccannizz11
You have to remove the plastic piece on the top of the front bumper just in front of the radiator..... I think
Did it last week. Took about 10 minutes. Here are the instructions I used. Easy to do.
http://wizardsworks.org/chod/acura/m6/
FWD tuna boat
it takes less than 5 minutes.
you just have to go under the front bumper and remove the plastic guard. then pull out the old bulbs, and insert the new ones (without touching the new bulbs with fingers)...very easy...
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
HeloDown
09-08-2015 06:51 PM
