Drivers side headlight hates me...
Old Apr 13, 2010 | 10:11 PM
Crod818's Avatar
Thumbs down Drivers side headlight hates me...
Has anyone else experienced this? Left headlight flickered off once, turned headlights off then back on, solved the problem. Now the headlight is no longer coming on and the 20 amp fuse keeps getting blown! I've self diagnosed this as the inverter, is that a correct assumption? I've done a search and haven't seen any results that are my situation verbatim. I haven't received my helm manual yet and don't really want to start tearing things apart until I know damn sure how to put them back together! Oh yeah, and did I mention my car only has 40K miles???
Old Apr 13, 2010 | 11:09 PM
brian6speed's Avatar
Lone Wolf
the ballast is known to go bad in our headlights
Old Apr 14, 2010 | 02:25 PM
clpassenubye's Avatar
ABP-KBP-CBP & ME
These are the exact symptoms of a bad ballast and you just need to replace it with a working one new or used.
Like brian6speed said it is a known problem with our cars and it just happens to be your turn.
I just replaced one of mine last month after going thru the same thing your describing.
Old Apr 19, 2010 | 01:18 AM
Bonez21's Avatar
Blown fuse = Bad ballast. I had this problem a few months ago...
I went aftermarket but if your interested i have 2 OEM Ballasts forsale check my sig.
Old Apr 19, 2010 | 08:27 AM
Nicks01CL-S's Avatar
"DD" Designated Drinker
my headlights have been causing problems. found out i had 2 loose connections. and now everything is fine. looks like someone half assed fixing it a while back
Old Apr 19, 2010 | 09:50 AM
PDGCLS01's Avatar
My Passenger headlight has been flickering here and there for over a year and it hasnt gone out yet. its only when they first turn on. I figure one day it will finally go...
Old Apr 19, 2010 | 10:15 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
def sounds like an issue with the ballast
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 16, 2015 03:29 PM
JnC
Sep 11, 2015 06:06 AM
