DRIVER DOOR RATTLE...HELP!!!! HELP!!! annoying!!
Old Mar 27, 2003 | 12:59 AM
mr. big's Avatar
Hey guys,
i have searched and couldnt find a soln to my driver's side door rattle going over bumps n such....it sounds like its commin from somewhere near the memory seat buttons...i have tried to press down on it but nothing....f
Do any of u know of a quick fix to the problem WITHOUT going to the dealer? i am hesitant to go there and complain since ive got back luck with this kinda stuff.....i just want to try to fix it myself...
Feedback would be much appreciated....thx all
Old Mar 27, 2003 | 06:48 AM
SilverKnight's Avatar
Retired. Not available.
Try to take a bumpy road with your hand press against the window glass (upper conner) to if the noise goes away.
Old Mar 27, 2003 | 07:27 AM
beerknurd's Avatar
Busy Living
I just had my door light pin switch replaced cause it was ratteling. I know that's on the other side of the door panel, but sometime rattles can be hard to trace.
I guess you can take the door switch out to see if that's the reason. it's a $13 part.
Old Mar 27, 2003 | 12:05 PM
mr. big's Avatar
so if i press my hand upon the glass and the rattles go away, what does that mean??
How do i fix it and what part is defective?
thx
Old Mar 27, 2003 | 12:06 PM
mr. big's Avatar
whats the door switch??
Old Mar 27, 2003 | 12:39 PM
beerknurd's Avatar
Busy Living
It's the black rubber piece that the door hits when shut. It's not on the door, but when the door shuts, the door hits this switch and that's what tells the car that the door is shut.
Old Mar 27, 2003 | 12:49 PM
thx
If that is the case, you have to find out the fix for yourself. I believed and verified with the dealer, no part is defective. Just the bad design. The window channel is not tight enough, thus, the glass moves around causing the squeaking noise. You can try to stick some clear thick tape to the top of the glass so it doesnt move as much.
Old Mar 27, 2003 | 03:54 PM
YuppieCL's Avatar
Moderator Alumnus
HOLY SHIT!
i have the same rattle! i can't figure out where its coming from! and yeah, its coming from the memory button. i've noticed that if u jam ur hand in between the dash and where the door stops, the rattle goes away
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
CadiGTi
Sep 14, 2015 06:37 PM
