Drifting with Comptech/Koni setup
Old Dec 30, 2003 | 01:46 PM
NW-CL's Avatar
Six Speeds
My Dad's had this setup on his car for about 5k.
See: http://www.acura-cl.com/forums/showt...=comptech+koni
Anyway, the car has started to drift at highway speeds if hands aren't on the steering wheel at all times. It's just a subtle drift (even on flat surfaces), it doesn't pull like an alignment problem, and it doesn't tend to go only to one side. I rarely drive the car and mine still has a stock suspension. So I'm not sure if this is normal with the comptech/koni setup. My Dad seems to think the problem is getting worse. Anybody experience this same issue?
Old Dec 30, 2003 | 02:03 PM
Chaptorial's Avatar
I've got the same setup as your pops. No drifting here. On a straight road if i let go of the wheel it remains straight.
If he's had it on that way for only 5k i can't imagine a major problem. How many miles on the tires?
Old Dec 30, 2003 | 02:07 PM
pimpscls's Avatar
THE SILVER BULLET
damn sucks man, its probably the alignment
Old Dec 30, 2003 | 02:33 PM
NW-CL's Avatar
Six Speeds
If I remember correctly he's got about 22k on his stock tires. What pisses me off is that I'm sure the dealership that put them on is going to give us the runaround.
Old Dec 30, 2003 | 08:46 PM
NW-CL's Avatar
Six Speeds
anybody else have any ideas?
Old Dec 30, 2003 | 08:50 PM
mattg's Avatar
it's either alignment or tires.
he should try X rotating the tires first.
Old Dec 30, 2003 | 10:07 PM
Roleez's Avatar
One or a combo of 3 things...
1) tire pressure
2) alignment
3) radial pull (tire imperfection ... rare)
Like mattg said... try cross rotation first (after you check and equalize all tire pressures). If rotation and tire pressure check don't work, get an alignment.
Jul 16, 2017 07:33 AM
yesSIR-S
May 13, 2016 05:42 PM
dirleton
Sep 25, 2015 12:25 AM
Sep 17, 2015 09:01 PM
