DOT 5 is not compatible with your car's braking system and can cause extensive damage
Old Sep 26, 2004 | 04:43 PM
Tosh's Avatar
Eurotrash
Just a little reminder from the informative owner's manual of my 2001 CL-S (p.229):
"Brake fluid marked DOT 5 is not compatible with your car's braking system and can cause extensive damage."
It also says you can use DOT 4 "as a temporary replacement."
This really should be the last word about DOT 5 brake fluid.
Old Sep 26, 2004 | 04:58 PM
Slimey's Avatar
Where is my super sauce?
:captainobvious:
Don't put water in your gas tank either. It's not compatible.
DOT 5 brake fluid is silicone based, whereas DOT 3, 4, & 5.1 are glycol based.
You could actually use DOT 5 if you rebuilt the whole brake system, but it's probably not worth the effort.
edit -- here's a nice concise brake fluid FAQ from a Triumph site http://www.vtr.org/maintain/brake-fluids.html
Old Sep 26, 2004 | 05:22 PM
NiteQwill's Avatar
Adventurist.
Um.... okay.
Old Sep 26, 2004 | 07:36 PM
mrsteve's Avatar
Old Sep 26, 2004 | 07:48 PM
Hobo's Avatar
Flap.
wow thats a great answer to a question no one asked
Old Sep 26, 2004 | 08:20 PM
DRM600's Avatar
<Insert random info from the user's manual here.>
Just a little reminder friends.
Old Sep 26, 2004 | 08:25 PM
Chopsie's Avatar
Beware of leakage
Shit! there goes my plans for next weekend
Old Sep 26, 2004 | 09:07 PM
mrsteve's Avatar
Just a little reminder from the informative owner's manual of my 2002 CL-S (p.77):
Each door has a master door lock switch. Either switch locks and unlocks both doors. Push the switch down to lock both doors and up to unlock them.
It also says that each door has a lock tab at the top of the door. When you push down the lock tab on the driver's door, both doors lock.
This really should be the final word on how to lock the doors.
car_lost's Avatar
is it compatible for the blinker fluid? i think mine is low.
Old Sep 26, 2004 | 09:08 PM
mrsteve's Avatar
Old Sep 26, 2004 | 09:11 PM
car_lost's Avatar
Originally Posted by mrsteve
what? how else would you explain the brake lamp light on my dash?
Old Sep 26, 2004 | 09:24 PM
JaredGMS's Avatar
Meat stick
Classic.
Old Sep 26, 2004 | 09:41 PM
Slimey's Avatar
...This really should be the final word on how to lock the doors.
Did you know you can also lock your doors with the remote?
By the way, when driving forward, turning the steering wheel to the left will make the car go left. Proceed with caution.
Old Sep 27, 2004 | 02:59 AM
ghost_masterCL's Avatar
that was great. pos-rep for you.
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
