Door Rattle - Help!
Door Rattle - Help!
I have a rattle in the driver door that is intermittent, but really drives me crazy. I have had in in to the dealer three times and they cannot find it. It sound almost like the window rattle (metal on glass sound), and it goes away as soon as put gentle pressure on the door panel just below the window.
Any suggestions? has anyone else had this problem?
I have the same rattle in my car, and the dealer can't fix it. They thought it was a bolt at the base of the window but it wasn't that.
I've since just given up. Until i get the time to take the door panel apart myself i've just been living with it
goredcar, I've got asimiliar rattle that the dealership thought they could fix by lubing the seals. I seemed to work for awhile, but now it's back. I'm not sure if it's the same rattle tho'.
My newest door rattle is sounds almost like static on the radio. If I open the window or put pressure on the window when it's closed, it goes away. I'm going to put matchbooks in the crack to see if I can quiet it up and then leave the matchbooks there so the techs know wtf is up...
I have also found that as soon as you bring the window down just a simdge, the rattle dissapears... so this is consistent with the windo pressure theory.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Just noticed that you're in canada... You might have a rattle like mine, but I don't have a low windsheild wiper fluid indicator like you cunucks do
![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
Doin' da crack shuffle
The driver and passenger door rattles are from the seals but it's not how you think. From the doors being open and shut over and over, the top of the door starts to bend outward (remember, it's only aluminum).
Here's the fix.
Be very careful doing this!!!!!!
Roll your windows all the way down. Open the drivers door will sitting in the driver seat. Turn your whole body left 90 degrees (still sitting in the drivers seat but with both feet on the ground). Pull the door closed until it rest on your knees (still with your feet on the ground). Grab the top of the door by the very top and gentle pull that part of the door towards you. Don't try to do too much at once. Do a little and test it to see if you still have the sqeaks. You don't want to bend it too far and cause creases in your door panels.
Here's the fix.
I've only got 25K miles on my car, and I've had the rattle since about 15K miles. I'm going to give this a try anyways tho', and will report back in the middle of next week...
Here's the fix.
Here's the fix.
damn dude...nice tip...
classic "door adjustment" technique. fyi this is how we got rid of squeaks and rattles at the ford truck plant in jersey....it also involved a large mallet too
Only in Canada eh!
Just noticed that you're in canada... You might have a rattle like mine, but I don't have a low windsheild wiper fluid indicator like you cunucks do ![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
[QUOTE=Red-CL]The driver and passenger door rattles are from the seals but it's not how you think. From the doors being open and shut over and over, the top of the door starts to bend outward (remember, it's only aluminum).
Here's the fix.
Thanks Red CL... I will give it a try... but I can't figure out how this will help. What is rattling? the door frame? and how come outward pressure makes the rattle dissapear?
Thansk for the tip though... I will try anything
Here's the fix.
You're kidding... you don't have a low washer fluid indicator? I don't get that at all. Do they figure that we only use washer fluid in the great white north?
Well, I tried Red-CL's suggestion and it seems to work (at least on my drive to work). It was a little cool this morning, so I'll see if it's "still good" when I go out for lunch.
I "pulled" the door twice this weekend. The first time, just a little. Went for a ride, and the creak was still there. 2nd time I applied a bit more steady pressure (nice and even no jerking), and it looks like it helps. Let's see how long it lasts...
It does indeed work. I have noticed a difference. No rattle/creak except for when I hit teh big bumps. Hafta give it a little more next time I think of it.
Must be a different rattle
Congrats.
Glad it worked out for you. I do mine at least once a year.
I also keep my tires inflated to the max. I am running ES 100's and was told by the dealer that performance tires should always be inflated to the maximim to get the best performance. So... tight tires also translates into more road vibration transmitted to the car.
Rattles, rattles and fixes
![Bounce](https://acurazine.com/forums/images/smilies/bounce.gif)
I am sure loose shit behind the door is the problem because as soon as I put light pressure on the door panel the rattles dissapear.
BTW - do (did) you also have rattles from your arm rest? I have this only when my arm is on it... so I just don't put my elbow on it. Kind of a pain in the ass as I really like using the arm rest. It doesn't seem ot matter whether it is slid forward or not.
Rattle, rattle, everywhere!
Allenn... thanks... I suspect that I am going to have to do the same. Any tricks to getting the door panel off? I assume you bought new door clips before you started.....
![Ripped Off](https://acurazine.com/forums/images/smilies/rippedoff.gif)
soupi
14
11-15-2015 11:15 AM
