Door Panel Schematic pic?
Old Sep 4, 2003 | 07:07 AM
CLean's Avatar
Cars are an addiction
I was wondering if anyone had a schematic of the 03 (I think 01-03) Door panel. I want to replace the wood trim from the CL-P with the aluminum trim from the CL-S. Someone said that you need to replace the whole door panel, but I want to see if there is a part number for the trim piece seperate.
I know the trim around the center console is easily replaced but the door is another story.
Any help would be appreciated.
Old Sep 4, 2003 | 10:45 AM
NSXNEXT's Avatar
Door panel is sold as one piece. You cannot just buy the trim piece separate. Easiest thing is to find someone that wants to swap the entire door with you. Oh and if you decide to remove just the trim piece on the door beware. It's a bitch to remove. You can to melt or cut the plastic rivets that hold it on. And then you need to figure out a way to reattach the pieces when you're done.
Old Sep 4, 2003 | 11:13 AM
CLean's Avatar
Thank-x
Hummm... Ummm Yeah.. The more I think about it I do like the wood look.........
Feb 25, 2020 09:57 AM
Aug 15, 2019 12:58 PM
VA2000TL
Oct 2, 2015 08:26 AM
wcimo
Sep 21, 2015 10:55 AM
CadiGTi
Sep 14, 2015 06:37 PM
