Does Gasoline Brands Matter?
I was near the Amerada Hess refinery yesterday and I noticed Exxon tankers pulling into the driveway. Are gasoline brands all the same? I know Exxon and Mobil merged, but Hess and Exxon?
From what I understand, gasoline is produced regionally and then farmed out to the different brands, just like you noticed at the Hess refinery. There are different additive packages to a particular brand, but the stock fuel is all the same.
well.......
unless you're in the southeastern US and buying gas at a shell station its all the same. shell apparently had a "SNAFU" in their recent formula. the gas was killing fuel pumps in cars that used it. i believe this happened last weekend. other than shutting down all the shell gas stations in the SE i don't know what other actions shell took for the damage the gas caused to car owners. bummer.
Originally Posted by carquest
well.......
It only affected a area of South Broward and North Dade. I'm in SW Dade (West of City of Miami) and we weren't affected. Try www.herald.com.
thank god I was in orlando that weekend
Yes, and...
Seems to be that way.
However, the additive packages are important.
Also, SOME discount stations that seem to have way-too-low prices may be getting less than optimal gas. IOW, stick to a station that you know – if possible. If you’re on the road -- good luck. Many years ago, I left Lost Vegas headed across country and got some really BAD gas. It was loaded with water and there was just enough gas mixed in to keep the car sputtering until I could purge the tank with fresh gas.
Useful link (where the quoted sections below came from):
http://vettenet.org/octane.html
A few vignettes:
Brand of gasoline:
Some of you probably know this; others may be shocked by it. Oil companies swap base gasoline all the time. Let's say I have a refinery in Houston and you have one in Dallas. It makes little sense for me to truck my Houston gasoline to Dallas and for you to truck your gasoline from Dallas to Houston when gasoline is a commodity product. So, I let you draw 100,000 gallons of base gasoline from my storage tank in Houston for your Houston gas stations, and you let me draw 100,000 gallons of base gasoline from your Dallas holding tanks for my Dallas gas stations. That way, we both save on shipping. Yup, Texaco gasoline may have come from a Shell refinery and vice-versa. At a gasoline terminal you may see trucks from up to six different companies all loading at the SAME terminal (that for example may be supplied exclusively by Shell). What comes next, however, is what makes Texaco Texaco and Shell Shell. Additive. Each company has its own additive and adds it to the base gasoline. So while the base gasoline may be the same, the additive is different, and hence the brand of gasoline you use is different because of the additive, not the base gasoline.
Octane:
I've seen many consumer magazines tell their readers that they are wasting money to buy a higher octane gasoline if their car doesn't knock. If octane were not related to any other feature of the gasoline, I would agree. However, how companies get higher octane gasoline does make it different than regular and mid-grade gasoline. So the question to me then is, do these differences make a difference? The short answer is what do I use, and I use regular in all my cars and my truck. I use premium in my Corvette. Why? Because as any Corvette enthusiast (to separate us from people who merely own one -- no flames, please) knows, a Corvette is not a car, it's an experience. If you want to know the long answer keep reading.
Base gasoline:
Crude oil differs depending on where it's from, and consequently, what comes out of it when it's refined also differs. There are books on the subject and I can't possibly do the subject justice here. As the oil differs, what is available for blending and cutting is different. In the end, however, the refiner has to make economic choices, based on what's available to him from the oil he is refining, on how to get the required octane to sell (as well as meet MANY other criteria that make gasoline, gasoline -- again I can't do justice to it here). What I generally (but not exclusively) see is that BASE (no additive added to it -- you can't buy this, it isn't offered for sale) premium gasoline leaves less deposits behind than other grades. There are certain types of molecules in regular and mid-grade BASE gasolines that simply do not exist in premium gasoline that cause much of this. Additives (see definition below) are added to the gasoline to help get rid of these deposits, and modern additives do a marvelous job of this. What you buy is additized gasoline.
Chevron note of possible interest:
Link: http://www.chevron.com/prodserv/fuel...cessbig3.shtml
When auto manufacturers design and build a new engine and emissions control system, they know they must prove to the United States Environmental Protection Agency (EPA) that the car can go a long way and still operate with very low emissions. That’s why, since 1973, all three major U.S. auto manufacturers use only Chevron gasolines to help their new engines pass the tough EPA 50,000 and 100,000 mile emissions system durability tests.
And they go a long way to prove it, because Chevron doesn’t market gasoline anywhere near the Michigan home of the Big Three automakers. They buy and use only Chevron gasoline with Techron, even though they must purchase it in Kentucky and pay to truck it all the way to the Detroit area.
Some of the real el cheapo stations have all kinds of junk in their tanks. Some from neglect and some on purpose. I've heard of stations buying cheap waste oil and mixing it in the tanks to lower the cost (to them) of the gas they sell. With gas prices where they are now, there may be more of a tendency for some unethical stations to do more of this.
Originally Posted by fuzzy02CLS
Don't matter to me. I buy whatever is cheaper. Gas is gas. Except the shaddy in the middle of nowhere back country road ones. I don't have any by me.
Though I buy Hess (full service-NJ, cheapest name brand and all), I totally agree. So long as my car isnt sputtering or knocking, the gas I get is doing the job.
well.......
here is the article:
"Shell pays drivers for tainted gas
Sulphur harms gas gauges in Florida
Canadians denied help for problem
TONY VAN ALPHEN
BUSINESS REPORTER
Oil giant Shell is reimbursing motorists in Florida for fuel gauge repairs made necessary by contaminated gasoline, something its Canadian subsidiary wouldn't do here last year.
An official for Shell Oil's refiner in the United States has confirmed it will start sending cheques today to customers who complained about faulty gauges after buying gas containing corrosive elemental sulphur from the company and Texaco.
Johan Zaayman, a spokesperson for refiner Motiva Enterprises, said yesterday Shell has received more than 9,000 claims for the cost of repairs in less than a week from customers in Florida and nearby states after the company acknowledged a problem.
"We're accepting claims from customers to get reimbursed for the cost of the repairs of the gas gauges," Zaayman said in a telephone interview from Motiva's offices in Houston.
"The cheques will begin to go out tomorrow (Friday)," Zaayman said.
In the last week, hundreds of Shell, Chevron and Texaco service stations have sold gas with traces of elemental sulphur, which quickly corrodes the contacts on sending units in tanks and, in turn, triggers faulty gauge readings.
Motorists have run out of gas and stalled when fuel gauges read full but tanks were actually empty.
Like Shell, Chevron says it has set up a special customer hotline and will cover the cost of repairs. Costs could range from $300 to $600 (U.S.), dealers say.
The reaction by Shell in the United States differs from how the company handled customers in the Toronto region last spring and summer.
A Shell official in Canada said yesterday the company handled customers appropriately here by sending them to their dealers for reimbursement of expenses.
"When we learned of the problem, we co-operated with our mutual partners (the auto industry) to understand it," said Simone Marler, manager of public affairs for Shell Canada Products.
"We then added an ingredient to our gasoline. We directed our customers to their dealers for assistance. Our goal was to make sure our mutual customers were looked after. And they were. The issue has been resolved."
Marler said she was unaware of the circumstances in the U.S. incident.
Unsuspecting motorists bought gas tainted with elemental sulphur at Toronto-area Shell and Petro-Canada service stations in the spring and summer of 2003. They got inaccurate gauge readings and stalling, a safety hazard on busy roads.
After a lengthy investigation, Shell and Petro-Canada concluded months later their gas contained elemental sulphur.
The two oil companies denied responsibility for the faulty fuel gauges. They stressed their products exceeded industry and government standards.
At one point, a Petro-Canada official said General Motors was responsible because it used an inferior part, but later the oil company said it wasn't sure what the problem was.
Shell sent customers back to their dealers, primarily GM, for reimbursement of repairs. But many customers expressed dissatisfaction with their treatment by dealers and GM's refusal to pay for repairs.
A Star investigation showed that GM had encourntered the problem in 2000 in parts of Canada and the United States.
GM sent a notice to customers warning them about the problem and corrective action but it did not issue a recall.
It redesigned the fuel sensors so they could tolerate elemental sulphur. However, the company only started using the new sensors in models last year. GM confirmed it accelerated the installation of the redesigned part in more models late last year.
The investigation found GM notified dealers on how to handle customers in last year's incident, but the company never warned customers.
Earlier this year, GM offered a free oil change and a Petro-Canada cash card worth a total of about $55 to customers who had gauge problems.
In Tampa yesterday, Skip Greaney, fixed operations manager at Gordon Chevrolet, said the number of repairs of fuel gauges in his shop shot up to 42 in May and 10 to 12 in the first two days of this month. There were only nine similar repairs in the first four months of the year, he added. "There's been a huge spike," he said.
Meanwhile, two women from Fort Lauderdale, Fla., who say the sulphur in the gasoline damaged their cars, have filed a lawsuit against Shell Oil Co. and Motiva, alleging the companies violated state law by engaging in unfair and deceptive trade practices. Shell owns half of Motiva.
The lawsuit says the companies "knew or reasonably should have known" that the gasoline with the sulphur would have damaged the vehicles but they continued selling the fuel to motorists."
http://www.thestar.com/NASApp/cs/Con...=1086300609655
Originally Posted by Chopper
Interesting article Baby. I hope it didn't make it over to Louisiana.
That is all over the news here in FL. However that is more of a quailty control mistake. I really don't think it was intentional. And it only effected a small % of Sun stations.
Originally Posted by Nashua_Night_Hawk
Wierd... how come the oil company does not market or at least explain to the consumers what kind of additive it uses that makes its gas brand better!
Texaco System 3.
Amoco Gold.
just off the top of my head
Since all gasolines, at least here in central FL. come from the same refinery the differences are not so great. Its just the additives that make the difference. That's why I carry Amsoil PI in the trunk.
RSpyder
Sep 30, 2015 12:46 AM
