Do you feel vribrations ....
Old Jul 5, 2001 | 03:25 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I do feel vribrations coming from the gas pedal with a slight vibrations in the steering at high speed (65-75 MPH).
Why is that?
Anyone had the same?
Old Jul 5, 2001 | 03:39 PM
ruvz's Avatar
YOOOOOOOOOOOOOO!
check rotors...
gas pedal does not vibrate..
Old Jul 5, 2001 | 03:42 PM
mcdanjw's Avatar
I get that... after I changed the wheels. Very slight, but there nonetheless. I bought the wheels & tires used, and noticed that there was some uneven wear (cupping) on the front tires. After I rotated them, the vibration wasn't nearly as bad, but I do have it a little still. I'm hoping new rubber will fix it.
[ 07-05-2001: Message edited by: mcdanjw ]
Old Jul 5, 2001 | 03:46 PM
Rock Dog's Avatar
FvCK KNvCKLE
Yeah, I mentioned this before. I releaved some of it by having the tires balanced on a Hunter GSP9700.
This car does have a certain amount of vibration that others do not. I seem to be more sensitive to it than other drivers. I've noticed my foot falling asleep if I drive for more than 45 minutes wth constant pedal 65-75 mph.
Do you drive with your right leg up agaginst the center console? I notice it a lot here as well.
Old Jul 5, 2001 | 03:57 PM
Happy CL-S Pilot
Yeah, sometines I do rest my right leg against the right center console...
However, I should have mentioned that my tires are 235/45/18 Nitto The low profiles tires could contribute more to the vibrations. Anyone with same Nittos?
Old Jul 5, 2001 | 05:09 PM
ZodiakTL's Avatar
Acura TL-S
i get the same thing after i've changed my tires to the bridgestone potenza re730s. there are still 17's(235/45/17) but much more sticky, i think thats what attributes to the vibration, the fact that it hugs the road a lot better and tries to go with the grooves there which are not even. when there is a really bad groove on one side, i sometimes have to literally fight the wheel to go straight at slow speeds.
Old Jul 5, 2001 | 05:34 PM
Fabvsix's Avatar
Cajun Gumbo Man
I had my rotors surfaced, new pads and NO more vibrations ! Car is like new again, with original tires. Current mileage: 33780
Old Jul 9, 2001 | 02:49 PM
rockinTLS_RENAMED's Avatar
TL-S "Auto" Pilot
Seems odd that a gas pedal vibration would be caused by the tires/brakes.
I have a TL-S with 2600 miles on it and noticed that while cruising I also had a vibration at the gas pedal. My car is bone stock with the factory Michelins.
Nashua Night Hawk: Did you get your issue fixed and how?
Old Jul 9, 2001 | 02:56 PM
Happy CL-S Pilot
The problem is still not resolved.
Vibrations are sometimes vert bad. Sometimes steering wheel vibrations are more noticeable. sometimes the gas pedal vibrates badly.
My best guess was the tires/brakes. I could be wrong. I would never thought that you would expect vibrations in the gas pedal in $30+ car!
I have to see what the dealer gona do..
Let me know if you can get that resolved.
Old Jul 9, 2001 | 03:31 PM
batra's Avatar
Dub Driver
You should call the city and check if NH is experiencing earthquakes
Old Jul 9, 2001 | 06:05 PM
Speed Racer's Avatar
I've been having the same problems. I had a RIM replaced awhile ago because I had hit a pothole and bent the orginial RIM. Since then, I've had the alignment checked, tires balanced, rotors turned and I still have vibrations from the steering wheel. I'm about to go nuts. I don't know what else to do??
MrHeeltoe
20
Feb 23, 2023 01:54 PM
mlody
Dec 4, 2019 02:11 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
