DIY:road lamps into HID fogs
Old 12-16-2009, 10:32 AM
  #41
Scepter's Avatar
Really interesting conversion! Definetly need to look into something like this. But my main question is: If you're calling them foglights now, why don't you have 3000K HIDs in them, isn't the definition of a foglight that the beam is yellow in color to cut through thick fog and inclimate weather?
jw lol
Old 12-16-2009, 01:39 PM
  #42
To many cars in my garage
MrFluffy's Avatar
I dont think that that is the definition but I think I would work better! but originally I wanted it to match but now I playing around with different color combinations to see what looks best and is the best to see with
I think what looks best is 3000k fogs and 30'000 headlights BTW yellow and purple but I cant see anything with 30'000k headlights
Old 12-16-2009, 08:03 PM
  #43
Scepter's Avatar
Originally Posted by I think what looks best is 3000k fogs and 30'000 headlights [B
BTW yellow and purple[/B] but I cant see anything with 30'000k headlights
I think you'd also have to worry about the Latin Kings then lol arent their colors yellow and purple?
Old 12-17-2009, 01:16 PM
  #44
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,353 Likes on 4,915 Posts
Are there Latin Kings in Canada?
Lol
Old 12-17-2009, 01:43 PM
  #45
MrFluffy's Avatar
Lol
I dont think so because I have no idea what u r talking about
Old 12-17-2009, 01:56 PM
  #46
civicdrivr's Avatar
lol
Old 02-08-2010, 11:25 AM
  #47
ThegreatGATHby's Avatar
+1 on the DIY.
I made the vent holes a bit different. One on the top outside corner and one on the bottom inside corner. I did this to prevent water from getting on the bulb and to promote cross-flow inside the lens. So far no problems. They are a bit dim, but I blame the nightshades tinting on the lenses I put on a while back... oh well. It looks cool [stealth].
Old 02-08-2010, 12:20 PM
  #48
MrFluffy's Avatar
I had tint on mine for a while it definley looks good I hate the look of the road lamps when there off they look cheap !!
Old 02-08-2010, 01:46 PM
  #49
Concave All Da Way!
mr2fast2thao's Avatar
i mite do this too, but with that big of a hole, wouldnt water just pour rite in and screw up ur electrict components!?
Old 02-08-2010, 03:50 PM
  #50
MrFluffy's Avatar
No everyone keeps saying that but unless you take out your headlight and pour water behind it your all good that fog light seals tight to the bumper !!!
just do it !!!
this spring im changing mine to retro fitted projectors I want more light out put and I hate the way our fog lights look when there off
Old 02-08-2010, 08:28 PM
  #51
Concave All Da Way!
alrite imma do mine then. gonna order a 3000k hid kit from ebay this week and hopefully get it done by this weekend.
Old 02-08-2010, 08:33 PM
  #52
MrFluffy's Avatar
Just a word of caution one of mine went out (and a headlight) so Im hopefully replacing the head light and the fog light this weekend so be carful because the balast got wet, I think so im going to wrap it in duct tape too try and keep the moisture away! I would suggest you do the same if you have any question just IM me
Old 02-08-2010, 08:53 PM
  #53
Concave All Da Way!
wow really, thats not good. well hope u get it fix. did u wire it to the headlight wires, cus i was thinking instead of wiring the hid fog to the headlight wires, why not make the hid fogs its own switch like the 02-03 tl fog switch, just to be on the safe side. would that still work?
Old 02-08-2010, 09:10 PM
  #54
MrFluffy's Avatar
yeah for sure but that switch is expensive I changed the wiring its now wired to a ignition switch because they are now my DRLs because my high beams are HIDs. But use a relay
Old 02-08-2010, 09:20 PM
  #55
MrFluffy's Avatar
I think the accord light switch on the accord fits but im not sure which year hopefully someone will chime in
Old 02-08-2010, 10:07 PM
  #56
Concave All Da Way!
Nice on making it DRLs
Old 02-08-2010, 10:59 PM
  #57
MrFluffy's Avatar
I drive alot at night so I wanted it to be bright
Old 03-15-2010, 10:05 PM
  #58
KatabaticSaint's Avatar
I want to hack the fog lights to operate without the headlights being on after i do an HID converison is there a DIY on this anywhere
Old 03-16-2010, 08:24 PM
  #59
MrFluffy's Avatar
What do you mean hack ?
do you have a cl or a TL?
Old 03-16-2010, 08:39 PM
  #60
civicdrivr's Avatar
Im pretty sure its a TL judging by his avatar. I think he wants his fogs to be independent from the headlight circuit.
Personally Id just add a completely new harness for them and run them off of that to let them run independently. Id leave the stock wiring there just so its easy to go back if need be.
Old 03-17-2010, 05:33 PM
  #61
MrFluffy's Avatar
agreed but I I would use the OEM switch
Old 06-07-2010, 02:41 PM
  #62
Kyauk's Avatar
thank for diy
Old 06-07-2010, 02:42 PM
  #63
Kyauk's Avatar
any pics of 3k hid road lamps?
Old 06-07-2010, 10:57 PM
  #64
k bye's Avatar
pics loading for anyone else?
Old 06-19-2010, 05:09 PM
  #65
RideCL's Avatar
So I have my Fogs hooked up to a 2001 honda accord switch. I had to have someone do the wiring..was not too easy. But it works. I am currently trying to install the HID bulbs into the foglight housing. How did you guys get the bulbs to stay in. They are H3 right? they dont just twist in????
Old 06-19-2010, 05:41 PM
  #66
civicdrivr's Avatar
Im pretty sure they arent H3 bulbs.
Old 07-18-2010, 10:37 PM
  #67
Triple "T"
8my-cls01's Avatar
Did anyone else run into a problem when they 1st tried this? If you did, how did you end up getting it to work? I obviously don't know what the he** I'm doing wrong. I followed the instructions but no luck. The only thing I was able to do was fry the fuse for the right head light. Can anyone help me out?
Thx
Old 07-25-2010, 12:53 AM
  #68
mksliao's Avatar
+1 for the DIY, really wanted to put hid on those road lamps, buy didn't buy the fogs as i also heard about the heat, first thing Mon will pick up the fogs from the dealer. you are a life saver.
Old 07-25-2010, 08:11 AM
  #69
civicdrivr's Avatar
What fogs?
Old 07-25-2010, 01:28 PM
  #70
k bye's Avatar
i did this mod and even with the big holes i can still see some melting of the housing but its not bad. the only problem i had was water getting into the foglight when it rains. so i drilled two tiny holes in the corner to drain and solved that problem. so as of now its working great with 3k hids. i have my ballast mounted inside the bumper support beams.
Old 07-25-2010, 05:26 PM
  #71
03type_s6speed's Avatar
Hey 2 quick questions. Where's a good place to buy road light assemblyother than dealer ship and also how would I wire them so they turn off wit high beam?
Avenger411
10-11-2015 03:53 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
rhdune16
09-28-2015 11:31 AM
h22lude
09-27-2015 06:22 PM
Quick Reply: DIY:road lamps into HID fogs
