Ding in UT Crank pulley Is it a problem?
Does the belt hit that part of the pully? If not I would not think it to be a problem. It minor so I don't think balance will be a problem. But hey, if the seller will send you a new, I'd send it back.
just get another one = return and get another or get a cheaper UR pulley.
itz up to u. i am sure its not a biggie but i just rather use smthng i know was in the best of conditions to start with . .....2centssssss
Former Sponsor
I've seen that before and I have asked UR. They have told me it won't affect it and it's not b/c it's a sales pitch b/c it didn't happen when it came from them. If you want you can use a small file to make sure it isn't sharp. If it were on the grooves it might be an issue with causing issues with the belt but not on the edge.
Just send them back a response and say, "great, I guess you will assume liability if this directly leads to any issues down the road since you are so sure"
I have been searching for almost an hour trying to find the size of the crankshaft bolt. I found alot of threads complaining about how much the pulleys cost but nothing on the bolt size.
It occurred to me to look on oemacura and I did not find the bolt size but I did find that the stock pulley lists for 100.00!
http://www.oemacuraparts.com/partloc...layCatalogid=0
Can anyone tell me what size the crankshaft pulley bolt is please?
Whats up with RDX owners?
17 or 19. Im leaning towards 19 though.
SidhuSaaB
05-30-2020 12:40 AM
