diagnostic trouble codes for J32A2 engine
Old Jun 23, 2005 | 02:37 PM
manitou's Avatar
I own an Acura CL-S 43,000 miles. Lately it has been throwing random cylindor codes along with a 209 code of which meaning I am unaware.
I have installed: Comptech ESM, header, exhaust, sways, springs.: UR crank pully: AEM CAI w/ 5 Spiral Max swirlers inside, & pully set: The 209 code occured when a Hurricane chip was connected, but only after I installed the Thurmablock system. After which I disconnected the Hurricane chip because it was somehow messing with the Air reading 40 instead of 150. Can anyone out there enlighten me on what is causing the codes
. The Acura Tech seemed to have no clue; only stating that I must have gotten some bad gas, or the fuel injecter cleaner was causing the PCM to think that there was a problem. HELP!
Old Jun 23, 2005 | 03:10 PM
manitou's Avatar
Old Jun 23, 2005 | 03:28 PM
mrsteve's Avatar
First: If you aren't running boost why do you have the Comptech ESM?
Second: What is the Hurricane Chip?
Third: Air readings of 40? 150?
Old Jun 23, 2005 | 03:36 PM
manitou's Avatar
error codes
On my last post I made an error. The undocumented code should read P560 not 209.
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
ghuns
Sep 16, 2015 04:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
