Deck Height
Old Feb 23, 2006 | 02:11 AM
g35_sc's Avatar
Deck Height
Is the deck height on the j32a2 and the j35a5 and the j30a4 the same....i have read that the 3.2 is a bored out 3.0 and the 3.5 is a stroked 3.2. Now going with, if A=B and B=C then A=C.....if the 3.5 crakshaft can fit into the 3.2 can it also fit into the 3.0, if what I sated before is true? Also, that would mean all three have the same deck height
Old Feb 23, 2006 | 08:15 AM
Zippee's Avatar
Do a search for details, this has been done before.
As I recall you also have to change rods and pistons if you put the long stroke crank in a 3.2.
Old Feb 23, 2006 | 09:13 AM
CleanCL's Avatar
from what i understand you just need rods and crank from an mdx to stroke the 3.2 to 3.5
Old Feb 23, 2006 | 10:11 AM
g35_sc's Avatar
i know that one, but i have the j30a4 engine. 02av6 did the swap in with the oddyssey crank and rods and rl pistons, i believe. But i want to do the j30a4 with the mdx crank and rods with my stock pistons.
Old Feb 23, 2006 | 11:12 AM
CleanCL's Avatar
yea but i think 02av6 used the j32a2 block, i don't think you will have enough clearance on your motor.
Old Feb 23, 2006 | 01:35 PM
g35_sc's Avatar
even though they are the same deck hegiht?
Old Feb 23, 2006 | 01:53 PM
CleanCL's Avatar
i'm sure it's more than just deck height or else the accord guys would leave their block and head, but as far i know, they need to swap both in order to get the 3.5 in there.
Ratheruneeq
Sep 28, 2015 07:41 AM
Sep 25, 2015 06:05 PM
flybyglass
Sep 24, 2015 01:12 PM
4drviper
Sep 23, 2015 07:42 PM
rboller
Sep 23, 2015 02:49 PM
