Debadging Question
Old Aug 30, 2001 | 11:07 PM
RMGCL-S's Avatar
Bling Bling
Debadging Question
What is the best method of debadging the anus aside from ripping them off. Is there a better method than that?
Old Aug 30, 2001 | 11:08 PM
RedLineTypeS
Guest
Posts: n/a
Use a hair dryer and dental floss Everyone says its the best way to go
Old Aug 30, 2001 | 11:09 PM
foe's Avatar
foe
Heating them up first definetly helps.
Old Aug 30, 2001 | 11:10 PM
cl-driver's Avatar
If its really hot outside (90+) you won't need a hairdryer. Becareful with the paint when using the hairdryer. And try to wear gloves when using fine dental floss.
Old Aug 30, 2001 | 11:17 PM
SidVicious's Avatar
Ambidextrous Masturbator
then wd-40 to get the rest of the glue off. then some zaino or other wax to protect it again.
Old Aug 30, 2001 | 11:48 PM
TypeSKid's Avatar
Hey, post a pic of the debadged anus when you get it done.
Do alot of you guys have it done?
Old Aug 30, 2001 | 11:49 PM
Technique's Avatar
Ya, just wear gloves with the floss, it'll cut ya...
Old Aug 30, 2001 | 11:52 PM
1StGenCL's Avatar
958 & 991
I just heated them up using a hair dryer and gently pried them off. Becare because they get hotter than you think and burn your fingers Then i took some rubbing alcohol to remove the rest of the gluey stuff. Waxed it and it's done
Old Aug 30, 2001 | 11:57 PM
Mr. CL-S 2U's Avatar
Don't do it!
Old Aug 31, 2001 | 01:22 AM
ChodTheWacko's Avatar
Moderator Alumnus
Originally posted by RMGCL-S:
<STRONG>What is the best method of debadging the anus aside from ripping them off. Is there a better method than that?</STRONG>
I used plain old floss, no cutting problems on my hands. I did use a sawing motion.
See my sig for pictures, and the FAQ.
Old Aug 31, 2001 | 03:51 AM
xxy1xx's Avatar
kwikCLvr
i used wd-40 first to "melt" the glue then i just "sawed" it off with floos....and since there was some glue left on the car i used TUFF STUFF and a rag and rubbed it off....it's really very simple
Old Aug 31, 2001 | 04:57 AM
rise's Avatar
i think our cars look GREAT without the A C U R A and the cl type S on the back, looks VERY clean, and not many cars are as clean as ours (no keyhole!). makes it even more distinct!
Old Aug 31, 2001 | 05:53 AM
Squishy's Avatar
Professional Pimp
I debadged my ACURA off my rear trunk... still debating my 3.2 Type S logos..
I like the look though.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
