DayTime Running Light Mod?
yeah, if you leave your lights on during the day, they will be daytime running lights. i'm not trying to be an ass. if you keep the light switch in the on position, they will automatically shut off after a short period of time after the car is turned off... then they will come back on when you unlock your car or open the door.
Originally Posted by fuzzy02CLS
Why would you want to burn out your expensive HID bulbs? Or expensive HID system?
I wish I had them too... But you have to to have a special module to get them.
If you've ever noticed you have an extra slot in the fuse panel for DRL's
Originally Posted by phipark
DRL are retarded.
there is really no point to having them except for getting the attention of
ITS DAYTIME! YOU ARE SUPPOSE TO SEE EVERYTHING WITHOUT HEADLIGHTS ON!
btw.. i hit the caps lock by accident and didnt feel like retyping what i wrote
They do? I though they used the low beams at reduced power?
Nope its highbeams at reduced power. Some cars such as the Corolla just use low beams.
The way it works is by cutting the curcuit to the highbeams on and off really fast.
You cannot have this on HIDs because of there on/off quickness they will actually flicker.
Only the car I've seen with HIDs as DRLs is the new GTI. But theres run at full intensity.
I'd personally only go for DRLs for a worth while insurance discount.
Our newer four door brothers in the TL (3rd gen) forum have a write up about DRL installation. Not sure if this would be the same for our cars, but I'm guessing it would be similar enough to give you a good start.
https://acurazine.com/forums/showthread.php?t=136827
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
does anybody know anything about the day time running light mod?
