Dash trouble lights
Dash trouble lights
On the way to work friday, three dash lights came on , and stayed on. They are the abs,vsa,and the vsa triangle lights. The car seems to operate normal. I disconnected the battery and reconnected it, but the lights remain on. The dealer said it could be several things that caused the lights to come on. I have a appointment monday to get it repaired. This is the first problem I've had with the car. It will be one year old on Oct. 25. Has anyone else had this problem? What was the repair?
i had the problem months ago.
the wire for the VSA sensor behind my right front wheel rubbed up against my CV boot and exposed the wire causing the same trouble lights.
i have electrical tape around it right now, but seems that tonight they came back on (a few hours ago :P )
so i'll check it out in the morning.
it's probably something similar for you, a VSA sensor malfunction is all. mine is just an exposed wire for that sensor
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
