Damn Icebox took me 5 hours to install. . .Got pulled over. .
6 Forward 1 Back
I'm not that great at installs, but thought I'd give this a try since it "looked" straight forward. I was going to do it Comptech's way by removing the bumper since I didn't have jack stands. Ended up getting all the hardware off and was removing the last screw under the grill and stripped it clean. . .
After a few curse words, put the bumper back together and then continued by removing the left front tire. I was going real slow because I was afraid I'd miss something. Too often there was something missing in the instructions that I would find on this board to watch out for. Thanks everyone for posting your installs. That helped a lot. I had my laptop in the garage while installing. My neighbor thought I was tuning the ECU or something. Little did he know how little I knew about car mechanicals.
The Icebox is great! It really pulls now more than ever! In fact I got pulled over by the police while I was doing a WOT run with my head out the window.
I was trying to listen to the "growl". Luckily he just gave me a warning. . I thought FOR SURE I was getting a ticket. . .
On another note. I noticed that the Auto-up/down on the driver's side didn't work until I put the code in for my Navigation and Radio. Could that be linked together??![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
And yes I do know what a turn clicky thing is. It's just the other stuff I have a hard time with.
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Do it! U Only Live Once!
You guys don't listen to me. I told you if you're not mechically inclined, forget this one. It took a professional mechanic 3 hours to install this on my car...without removing the bumper. Congradulations for having the patience for completing this job. Your a better man then me. Enjoy!
Where is my super sauce?
Re: Damn Icebox took me 5 hours to install. . .Got pulled over. .
Power Window Control Reset
Resetting the power window control unit is required after performing the following procedures:
2. Make sure the driver's window does not work in AUTO with the ignition switch ON (II).
3. Lower the driver's window all the way down by manual down using the driver's switch of the master switch, and then hold for more the one second.
4. Raise the driver's window all the way up by manual up using the driver's switch of the master switch, and then hold for more than one second.
- disconnecting of the battery.
- loss of electric power caused by both No. 8 and No. 15 fuses in the passenger's under-dash fuse box.
- open circuit caused by disconnected 18P connector from the power window control unit.
- removal of the regulator, glass, or glass run channel.
- open circuit caused by disconnecting the subharness attached to the door liner.
an adult perspective
Daily Driver
springs, sways, and icebox in 2.5 hours? It took me almost 2 hours to do my sways, although I'm far from a professional mechanic. Even so, that makes me wish I lived closer to PAA.
6 Forward 1 Back
Re: Re: Damn Icebox took me 5 hours to install. . .Got pulled over. .
Originally posted by Slimey
From the Helm manual:
6 Forward 1 Back
I'm excited... I'm looking at my CT headers and icebox right here in my living room as I type .. can't wait to get them installed in a month ... by a pro that is.
quanaman
01-09-2023 07:33 PM
IBankMouse
06-13-2020 12:53 PM
