Cross Drilled Rotors
I know Tim sells them on his site and want them really bad. but can't decide if I want the black cross drilled rotors and paint my calipers red or just get the silver cross drilled rotors and leave my calipers alone or paint them red or black.
another question is how come the rear rotors are more expensive than the front when there smaller??
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter.Polarg m-6.
Comptech Headers,Springs,Sways, Eurolite Xenon Crystal high beams.Polarg m6
gtech 0-60 6.03 w/ 438 pound load. preheader.
CL-S
Location: Somewhere between here and there, yet neither.
I want some black cross drilled too!! But aren't they a little expensive?
2001 Cl-S Black on Black with Navigation
Black Tint all around (15%~45%)
Weapon-R Dragon Filter
Weapon-R Coil-Overs
Koni Adjustable Struts
Comptech Sway Bars
Comptech Headers (hehehe...I got something for you drchang!!)
14.698 @95.977mph....Sears Point Raceway.I think I need a Level 10 Torque Converter!!
Yes, I know I'm going to hell for wasting gas on Civics....
My Peoples
Weapon-R Coil-Overs
Comptech Sway Bars
My Peoples
Stage 1 Audi S5
<font face="Verdana, Arial" size="2">Originally posted by g6317:
who is TIM and what site is this?</font>
No more scratches thanks to the dumbass who walked on my car and had to pay to have it repainted.
i'll take anything that works and keeps my getting sideways around turns with my e-brake
97 Black on Black 2.2CL
limo tint all around
1 alpine 12 in the trunk powered by an mtx amp
pics soon to come.
pics soon to come.
he has gold, black and silver, Gas slotted and cross drilled. But i remember someone who got the gold said the gold wore off w/ in a couple days. So im thinking probably the same for the black.
Would black calipers or red calipers look good w/ cross drilled rotors on a white type s? I also have the small comptech sticker that comes w/ the comptech parts on my rear passenger side.
The cross drilled rotors are around 300.
FYI tim also stocks acura parts. (new cup holder, matts and other goodies like ahmotor
CL-S
CL-S
- daemonichris -
damn i want some........!!!
Acura 3.2CL Type-S w/ Navigation
Black/Ebony
H&R Sport Springs | Pirelli P7000 Supersport 235/40ZR17 on stock rims | Neuspeed Tower Strut Bar | Custom CAI | Cleared Headlights, PIAA 19169 | Tint all around | Mesh Grill | Dual 12'' Alpine Type-S Subs | Kenwood KAC-728S Amp
Black/Ebony
The rear rotor "core" cost is more expensive prior to the drilling process. The rotors pictured appear to have too many drill holes, probably prone to crack too soon. Be careful with these.
MchtypeS has them and I wasn't too happy with them on close inspection.
Regardless of color, all the annodized material in the pad swept area is going to be removed.
On the rear rotors, make sure you chamfer the pad edge in both directions of sweep to prevent pad destruction.
<font face="Verdana, Arial" size="2">Originally posted by syncivic:
On the rear rotors, make sure you chamfer the pad edge in both directions of sweep to prevent pad destruction.</font>
Thank you very much for the responce, guess I'll just get the front rotors, and get the silver ones.
also what do u mean by 'chamfer the pad edge in both directions'?
CL-S
I've been told the following:
The cad plating wears away in time.
I would stick with the slotted rotors -- I did see them and they looked ok.
Cross drilled rotors really need good air flow to work well. Planning on installing air ducts? If not, they may actually hurt the brake fade (but do look cool).
You can take a file and put a slight bevel on the pad's leading and trailing edge. Do be careful, a lot of the brake pads have asbestos, so get a 3M fine particle mask when doing this. Better yet, ask a competent mechanic to do this for you.
It is possible to make a relatively good cross-drilled rotor, but the really good ones will get drilled very carefully and will have chamfered holes. They will also get some heat treating before cad plating to relieve any stresses in the rotor. Most of them will crack with time.
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 10 coats of Zaino magic
Would the rear rotors be more expensive since the inside surface of the rotor hat is also a precision-finished surface because the e-brake is a "drum-in-disc" unit?
Just a thought...
2000 WDP 3.2TL non-NAV
AEM CAI w/bypass, Comptech header
Just a thought...
why dont you just wait for the comptechs?
they will be about 250 - 300 for a pair
whats the point of buying STOCK rotors? theyll still warp over time. youll probably have even more problems with them
im sure the comptechs will have thicker walls to prevent warping
99 TL
99 TL
The Creator
<font face="Verdana, Arial" size="2">Originally posted by cl-driver:
are those stock rotors just drilled or are they a different brand?</font>
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
