Creaking Sound on passenger side
i have the same problem. i found it to be the dash trim right between the passenger seat and the center console. you could try to stick a foam piece in there
I had a creaking noise when I was driving over bumps on my TL. It came from my driver front, and I took in into Acura and found out that my ball joint and bearing had gone bad, my car only had 60,XXX miles on it! But I had the extended warranty and everything was fixed for a small deductible.
Press down on your hood on both sides and see if there is a creaking that comes from either side and you will have a good idea then.
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
