crank position sensor
Old Aug 21, 2012 | 06:13 PM
  #41
Rajca's Avatar
wham bam thank you ma'am
havent worked on the car for over a week. all my grounds are good, im gonna check to make sure my ecu is all plugged in. but i did get a iacv code last weekend. kept fluctuating all over the place but only when i would be stopped at a light. so im guessing its the harness. ill work on it soon.
Old Oct 8, 2012 | 07:50 PM
  #42
Rajca's Avatar
got a harness and installed it. now, still get the crank position sensor code (p0336) and my spedo and reverse lock out doesnt work. so im gonna go and recheck to make sure everything is plugged in. so unless its the ecu that gone to shit once again. idk what could be the problem
Old Oct 9, 2012 | 11:09 AM
  #43
fsttyms1's Avatar
Check to make sure all your grounds are in contact.
Old Oct 9, 2012 | 07:44 PM
  #44
Rajca's Avatar
one plug wasnt plugged in, plugged it in and spedo and reverse lock out works. still have the crank code. swapped in my other ecu and crank code still comes up. so my last guess is that its the fly wheel. but if others are running the same fly wheel. what is up with mine.
Old Jan 24, 2013 | 03:38 PM
  #45
Rajca's Avatar
ordered a new flywheel. gonna swap it out tomorrow
Old Jan 24, 2013 | 03:59 PM
  #46
fsttyms1's Avatar
What flywheel did you order?
Old Jan 24, 2013 | 05:41 PM
  #47
Rajca's Avatar
luk oe replacement
Old Jan 24, 2013 | 09:19 PM
  #48
1foxbody's Avatar
03 CLS-6
Shouldn't have any problems with the new one hopefully . What pressure plate and clutch disc are you going to use with it?
Old Jan 25, 2013 | 04:30 AM
  #49
Rajca's Avatar
stage 2 clutchmasters pp and p2r 6puck disc
Old Jan 25, 2013 | 06:35 AM
  #50
fsttyms1's Avatar
I still need to get a light weight flywheel.
Old Jan 25, 2013 | 07:01 PM
  #51
civicdrivr's Avatar
Yes.
Old Jan 25, 2013 | 10:37 PM
  #52
Rajca's Avatar
guess what, car revs over 2k rpm. finally
Old Jan 25, 2013 | 10:49 PM
  #53
civicdrivr's Avatar
So what was wrong with the lwfw?
Old Jan 26, 2013 | 08:22 AM
  #54
fsttyms1's Avatar
Did you compare the 2 flywheels side by side or laying on top of each other to see if there was a difference?
Old Jan 26, 2013 | 09:02 AM
  #55
Rajca's Avatar
no clue what was wrong with the lwfw. i compared them every which way and measured everything and it all matched up. the crank trigger notches on the lwfw were 1/16th narrower then the ones on the oem flywheel but thats the only thing that i could find. different
Old Jan 26, 2013 | 11:53 AM
  #56
Rajca's Avatar
so i couldnt do what i wanted (oem flywheel, p2r disc and the clutchmasters pp). the disc was loose when the pp was installed so i reused my old stock pp and p2r disc. bc my pp is so worn out that the car isnt drivable. but the good thing is that it revs fine so ill be ordering a oem pp and disc for the time being
Old Jan 26, 2013 | 05:14 PM
  #57
OperationDarkie's Avatar
Ultra Negro
now you can help me change my clutch :P
When it warms up of course
Old Jan 27, 2013 | 09:11 AM
  #58
Rajca's Avatar
Sure thing. Anyone ever heard of sach clutches?
Old Jan 27, 2013 | 04:53 PM
  #59
CL-Future's Avatar
Lives in Boost
Me, you, Brian and some other mid-western Azine'ers needs to have a track day around the same time as the one on the East coast. It would be a pretty good time.
Old Jan 27, 2013 | 06:18 PM
  #60
Ultra Negro
hmm I rather have a drink day, or better yet I'll ride with Tom, so I can drink and you guys can have the track day
Old Jan 27, 2013 | 06:55 PM
  #61
CL-Future's Avatar
Lives in Boost
Either way. As long as we get some runs in lol
Old Jan 27, 2013 | 09:39 PM
  #62
fsttyms1's Avatar
Im in for a track day.
Old Feb 9, 2013 | 03:50 PM
  #63
Rajca's Avatar
well, with the oem fly wheel and oem clutch. the car runs great. put just over 200miles on the clutch so far, and besides needing more fuel in the higher rpm, the car drives great.
so i sent out the clutchmasters stage 4 kit last week and no im waiting for what they are going to say about the flywheel
Old May 7, 2013 | 02:16 PM
  #64
PinkBatman's Avatar
7th Gear
Bump. I am having the same code with the same flywheel. Did you hear any news back?
Old Apr 13, 2014 | 06:51 PM
  #65
Vic87's Avatar
im having same issue with the clutch master fx400 kit what a waste of money
Old Apr 16, 2014 | 05:01 PM
  #66
Rajca's Avatar
they flywheel was teh problem. sent it back and put in a luk flywheel and oem pp and clutch. all good
Old Apr 16, 2014 | 05:05 PM
  #67
Rajca's Avatar
also they didnt find anything wrong with they flywheel. so idk. maybe a tooth was off but a tiny bit or the magnetic sensor wasnt picking up any signal for the teeth bc they are offset too much? no clue.
Old Aug 28, 2014 | 04:31 PM
  #68
richardparker's Avatar
3.7L Nitrous Breathing CL
Any of you guys get this clutch kit sorted out ?
I just bought this kit and now seeing this I feel like I'm going to have to deal with a return issue.
Old Aug 28, 2014 | 05:05 PM
  #69
Trying to cancel my ordered but their closed.
Of course.
Added this page to their email with hopes they will understand and not hit me with restocking fee's.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
RobbDizzle
Oct 15, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
