Controlling Nitrous with E-manage
Old Sep 29, 2004 | 01:12 AM
MotionEffects's Avatar
Acura TLS are SLOW
Would it be possible to control Nitrous using the E-Manage? I have a Zex kit and I would like to control nitrous with the E-manage to come on at certain RPM and shutting it down before it hits fuel cut. Maybe the additional injector harness could be use to send a signal to open the solenoids
Old Sep 29, 2004 | 01:20 AM
mattg's Avatar
i think scalbert is working on that.
my unichip controls my zex dry shot. it's able to pulse the solenoid for a progressive launch and most importantly it shuts down the nitrous at 7000 rpm so i can't hit the fuel cutoff while spraying.
it also eliminated the need for the TPS switch. it's all done off the ecu.
Old Sep 29, 2004 | 02:40 AM
goldmemberer's Avatar
goldmemberererer
Originally Posted by mattg
it also eliminated the need for cover sheets on the TPS reports. it's all done off the ecu.
Old Sep 29, 2004 | 11:42 AM
Acura TLS are SLOW
Did you change the solenoids or did you kept the purple box and manage to control the unit using the Unichip? And also does Unichip retard the timing aswell when it nitrous is applied.
Old Sep 29, 2004 | 12:31 PM
darrinb's Avatar
///M POWER
do u have to go to a different map on the gas matt??
Old Sep 29, 2004 | 02:46 PM
mattg's Avatar
the box is still being used w/ the original solenoid, it has been rewired though. i have 2 settings for the chip, the street mode that has advanced timing, and the strip mode (nitrous) that retards timing.
when the swith is flipped, it arms the system and changes the ecu maps.
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
