Conformation
Old May 18, 2006 | 09:58 AM
bim6180's Avatar
Conformation
Hi all..
Just to confirm this, If i'm changing my rotors and pads (not brake lines), i don't have to bleed the brake fluid right? You only do that when you're changing the brake lines right?
Old May 18, 2006 | 10:01 AM
MarbleGT's Avatar
'08 MX5 GT 6spd.
I didnt when I changed mine out.
Old May 18, 2006 | 10:10 AM
Excelerate's Avatar
Former Sponsor
Originally Posted by bim6180
Hi all..
The brake fluid does not need to be changed when changing rotors and/or pads. However, sometimes people choose to flush out the brake fluid and put new fluid in there because overtime the fluid breaks down from repeated use, repeated heating up and cooling down, and eventually a small amount of water/condensation gets into the fluid reducing the efficiency.
Old May 18, 2006 | 10:43 AM
NSXNEXT's Avatar
You only need to bleed the lines when you allow air to enter the brake system. An example would be disconnecting the brake line from the caliper.
So you do not need to bleed the lines.
csmeance
Jul 11, 2008 08:52 PM
imaginary17
Dating & Relationships
Apr 11, 2008 01:28 PM
imaginary17
Apr 11, 2008 01:19 PM
GoDucksCLSPride
Money & Investing
Oct 22, 2005 07:34 PM
