Condensation in and around center brake light
So today I noticed some pretty heavy condensation where the center brake light is. I know I know:
but the thing is I am sure you all know what condensation looks like and my camera is in the repair shop (sand + digital camera + moron=broken camera) It is almost all right where the light is. Anything I can do to easily fix it? I have a sub (1000+ watts RMS) and my only idea is that maybe the sub rattled something loose that allowed air in there. I looked around and sure enough there was a little piece of black plastic that surrounds the light that came loose. I pushed it back into place, but I know it will just come back out again the next time I drive. Should I just use some 5 min epoxy or something like that? What do I need to do to get rid of the condensation before fixing the loose plastic?
Any thoughts would be greatly appreciated. Thanks
Drive it like it's HOT!
if you're talking about the 3rd brake light, it's not sealed to the window. probably a 1-2 mm gap. if you wanted to clean that part of the light, you have to remove the rear seats, rear shelf, and then go into the trunk. you should find 4 nuts holding the brake light in place. but as for condensation, i've never gotten that before.
Originally Posted by fuzzy02CLS
It's held on with 2 nuts.
I'm confused though why there's condensation in it. It's not an outside exposed part. Unless you left your trunk open. Or you have a water leak around your rear window.
People don't believe me when I say I'd rather have a car without a sunroof...
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
