Concern about Pro-kits, calling on Moomaster
Old Jan 30, 2002 | 10:13 AM
BigPimp's Avatar
Moomaster_99
You're gonna rub...the pro-kits are too soft for the car..ask bobowah...
I think we went through every suspension on his car already...
Whatever you do...don't use the pro-kits...they are made specifically to ride like stock for an Accord v6...which means...softer than a CL-P...and nowhere near the spring tension needed to keep the CL from bottoming.
Ok whats up with this Moo, is this true. Can anyone verify this? Because I have the pro-kits and I deffinetly have my doubts about whethey they should be this way, meaning sitting too low and even prone to buttoming? If this is the case, I think I am gonna try to get them taken out this weekend.
Old Jan 30, 2002 | 10:38 AM
ruvz's Avatar
YOOOOOOOOOOOOOO!
heheh...I doubt the car will bottom out... I have had my pro-kits for 6+ months and no probs whatsoever...
Old Jan 30, 2002 | 10:57 AM
Cee eL eS's Avatar
i've seen GCs, H&Rs, Eibach Pro-kits, CTs, and Apex-i suspensions on mine, bobowah's and moomaster's cars. by far the pro-kits sit the lowest in the back. if your gonna stay w/ the stock rims and tires, u might still be ok, but over time, the suspension will drop even lower once the shocks start going out. upsizing to 18s and 19s will definitely rub, even w/ the fenders rolled...
Old Jan 30, 2002 | 10:59 AM
ruvz's Avatar
YOOOOOOOOOOOOOO!
Obviously springs settle and start sagging, but I don't think that the Pro-kits are that bad...
What makes the Comptech's better?
Old Jan 30, 2002 | 11:00 AM
BigPimp's Avatar
Well, my car does not buttom out, it just seems soft and this makes me worried. It makes me believe that what moo is saying could be factual.
Cee eL eS's Avatar
imo not necessarily better, just that the drop isnt as low on the CT springs, so more room to up upsize rims and tires, and no need to roll fenders...
Old Jan 30, 2002 | 11:02 AM
ruvz's Avatar
YOOOOOOOOOOOOOO!
The ride on Pro=kits is pretty tight... I really don't feel anything soft about them..
Old Jan 30, 2002 | 11:23 AM
amir was here's Avatar
how is it that other members are riding on the pro-kit with 18" rims and not reporting this?
Old Jan 30, 2002 | 11:48 AM
bobowah_RENAMED's Avatar
suspension dude
okay
I have almost every suspension there is for this car
Suspension #1 Stock -> rides luxo... but too high
Suspension #2 Had Ground Controls and Konis on the car.
I did not like them too much b/c they rode really harsh for me.
The handling was amazing, 17x7.5 with 225/45/17 kumhos
Suspension #3 H&R sports and stock shocks... fawker who installed it messed up and front right suspension dropped out and busted my strut hat. but otherwise rode pretty good, 17x7.5 with 225/45/17 kumhos
Suspension #4 Eibach ProKit + Koni Yellows. The ride is good but not as good as the H&Rs... I rub alot with this config. Rubbed with the 17x7.5 with 225/45/17 kumhos. And now with my 18x8 OZ Superleggras 225/45/18 I rub over almost everything. I hit the rear bumper flange. So I've even rolled the rear fenders. Its better but I'm still tearing away at my Bridgestone S03s...
Suspension #5 Apexi coilovers on there way... I'm probably going to rake the car b/c of the rubbing in the rear.
My take on the deal... I should have kept the H&R and konis and probably gotten 225/40/18 instead...
So there...
Old Jan 30, 2002 | 11:53 AM
boboh, which H&R's?
what was the offset on you 17x7.5 rim?
what about your 18x8 whats the offset?
why did u get a 45 series, maybe thats why you were rubbing..
with a 40 series, if the offset was right, you might not have rubbed.
Old Jan 30, 2002 | 11:54 AM
WiLd~CL~TYPS-@SS's Avatar
I love my CL-S
Mine wont rob at all, but i have weird noise coming from the rear when the road is bumpy
Old Jan 30, 2002 | 11:55 AM
ok i saw in your sig...
so, i read the 45 offset is only good with a 7.5 wheel...u have 8"
also, you have a 45 series tire...
if your rim was 45 offset with 7.5 and a 40 series tire, i dont think you would be rubbing, would you?
Old Jan 30, 2002 | 12:01 PM
suspension dude
amir
if I had a 40 series tire it would be a non issue... I got the recommendation for the tire from Comptech... b/c that what they had on their SEMA car... I forgot though... the Comptech springs are higher in the back... thus my rubbing with the Eibach Prokit... saggy butt springs...
Old Jan 30, 2002 | 12:07 PM
okay bobah.
i need your help,
with a
18 x 7 with a 42 offset, and 225/40/18 tires, and dropped on prokit with 2 12" subs in the back.....will i rub?
if i do, will it be minimal, therefore fixed with rolling?
Old Jan 30, 2002 | 12:09 PM
Cee eL eS's Avatar
okay bobah.
i need your help,
with a
42 off-set MIGHT be too low...it helps w/ the 40 series tires tho...i wouldnt roll w/ any passengers in the back tho...
Old Jan 30, 2002 | 12:11 PM
suspension dude
really depends on your wheel...
you need to look at where it sits on the fender
the outer part of the tire on my s03 hit the fender... we rolled all the metal parts of the fender to clear the tire... but I hit the flange that connects the fender to the bumper. You really can't do anything about that...
with the 40 series tire most likely you have more clearance than I will... but the +42 offset might just put the wheel and tire closer to the edge of the fender...
Old Jan 30, 2002 | 12:12 PM
suspension dude
btw
I had two passengers in the car with luggage and rubbed over everything... bumps... imperfections in the road...
but the guy up front was pretty heavy...
Old Jan 30, 2002 | 12:18 PM
if 45 offset is okay for a 7.5 wheel, why wouldnt a 42 offset be ok for a 7" wheel?
Old Jan 30, 2002 | 12:26 PM
suspension dude
amir
again it really depends on the rim...
the offsets vary from vendor to vendor...
All I can say is try on rim and tire combo... don't buy all four rims.. just get one... and try to work something out with your store..
-J
Old Jan 30, 2002 | 12:34 PM
i'm buying online
bobah what if it fits on a 00 accord coupe, also with pro-kit..does that mean it will be good with our cars too?
Old Jan 30, 2002 | 12:36 PM
suspension dude
if you are buying from tim I would not worry too much
but if you can see if you local tire dealer or rice shop can get one rim mounted with tire then see if it fits...
Old Jan 30, 2002 | 12:42 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
i'm buying online
No...accords have the same offset...but they have a lot more play in their wheelwell area...
Old Jan 30, 2002 | 12:56 PM
4pumpedCL's Avatar
Honkey
With the right offset you won't have any rubbing, at any height. Doesn't matter if you have H&Rs, Ground Controls, anything...my car doesn't rub at this height, and the suspension is completely bottomed out....with 19x8" rims 50mm offset. Also, for those of you feeling the suspension bottom out...cut your BUMP STOPS, it'll solve the problem.
Old Jan 30, 2002 | 01:02 PM
BigPimp's Avatar
Originally posted by 4pumpedCL
[B]Also, for those of you feeling the suspension bottom out...cut your BUMP STOPS, it'll solve the problem.
Bump stomps have been cut, but I still think the springs are too soft for this car, just like Moo said. These are accords springs. However, eibach site does recommend them for the CL as well.
I agree the right offset is ideal....but look at what kind of rims are available in a 50+ offset...not much of a selection...and IMHO...most of them are that great looking...
Old Jan 30, 2002 | 01:16 PM
4pumpedCL's Avatar
Honkey
I rode around with my stock (soft) CL-P springs sporting 3 coils cut off them. It had a lot of suspension travel, and never bottomed out. The car was tucking rim in the back and nearly as low as I could go in the front and still turn... Perhaps you should cut more bumpstop. I had mine trimmed down to 1/4" and the ride was fine.
Old Jan 30, 2002 | 05:36 PM
Paul750's Avatar
I have the pro-kits and i cut two coils off the front and back and dont have any bottoming problems at all
Old Jan 30, 2002 | 10:56 PM
AztecRol's Avatar
The Screeching Toyo's
Originally posted by bobowah
btw
You calling me or moo FAT??????????? Damn bitch, I thought you were are friend?????? Damn moo, next time you see him, hit his azz!!!! Hit him hard too!!!!!
:pfawk:
Old Jan 31, 2002 | 12:40 AM
HellaWhat's Avatar
*Hella* isn't a word.
:pfawk:
This is the person Bobowah is speaking of ...
Old Jan 31, 2002 | 10:59 AM
BigPimp's Avatar
Wait wait wait a minute here........You did what? You cut the coils on the pro-kits????????? Please explain
Old Jan 31, 2002 | 11:22 AM
fbazakos's Avatar
on bin laden
dammit aaron, everytime i see that pic i wanna pour out some liqour for BOYD and then :wackit:
Old Jan 31, 2002 | 12:55 PM
suspension dude
:pfawk:
Nah Rolie
when you guys were in the car it was fine...
it was when I had another set of friend it there with luggage it was rubbing alot more... with my 18s
-J
Old Feb 5, 2002 | 10:24 PM
Paul750's Avatar
cutting the prokit
Yeah! I got a set of the Pro-Kits and wanted it lower so i cut 2 more coils off each spring!
emailnatec
29
Sep 28, 2018 04:27 PM
thegipper
Sep 28, 2015 01:01 PM
mars
Sep 28, 2015 11:03 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
