Comptech springs lower on driver's side...help!
Old Mar 21, 2001 | 07:43 PM
Rayan's Avatar
4th Gear
i just got my comptech springs installed yesterday at the dealership. i love the handling and looks, BUT the front driver's side of the car is about 3/8" lower than the front passenger's side.
anyone else have this problem?
the dealership said that its probably a normal variance in the car, but i never heard anything about it on acura-cl, nor could i notice it in any of the members pics.
what do y'all think?
Old Mar 21, 2001 | 07:46 PM
WebToker's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rayan:
</font>
They need to make sure they put the springs on the right side. There is a spring for the left and the right.
2001 Acura 3.2 CL Type-S
Comptech Springs
Apexi V-AFC
AEM CAI
Old Mar 21, 2001 | 07:48 PM
fender4's Avatar
nope, not mine. call Comptech, sounds like the installed spring is not seated correctly in the strut tower. Jens where are you, this is in your line of work.
Old Mar 21, 2001 | 08:30 PM
dlp's Avatar
dlp
i can't help but laff a little.. just imagining you driving down the street dropping lsightly toward the window.. everyone around wondering if the car has hydraulics. . . :-) I would take it back to the dealer and say there is nothing normal about the drop pn one side over another...
2001 CL Type S w/ NAV & Spoiler. San Marino Red/Parchment int. Purchased 2/28/01.
http://albums.photopoint.com/j/AlbumIndex?u=1584587&a=12058921
Old Mar 21, 2001 | 08:56 PM
tankmonkey's Avatar
6 speed...
</font>
I'm just impressed that you noticed a 3/8" (<10cm!) difference from left to right on the car...
did you use a bubble level or plumb bob or something? (laser survey equipment?)
did you try to measure from the ground to a particular point on the car? (and if so, did you take the same measurement from the same point on the car in the same place on the pavement to be sure the difference doesn't lie there?)
[This message has been edited by tankmonkey (edited 03-21-2001).]
Old Mar 21, 2001 | 09:03 PM
Jayru's Avatar
<font face="Verdana, Arial" size="2">Originally posted by tankmonkey:
</font>
I Think the solution is simple to finding the Measurement.
Simply measure from the top of the tread on of tire to the bottom of the fender (the Wheel gap should tell you if they are set ok)
Old Mar 21, 2001 | 09:07 PM
tankmonkey's Avatar
6 speed...
<font face="Verdana, Arial" size="2">Originally posted by Jayru:
</font>
I agree, but if the pavement is uneven, the measurement may be affected. hence, the need to perform the measurement in the exact same spot on the pavement, both before and after. and, again, we're talking about 3/8" here...
Old Mar 21, 2001 | 09:20 PM
Al Uminum's Avatar
Webtoker is right. The springs, if I remember correctly were labeled left and right to compensate for the weight of the driver. The puzzling part is that you probably were not in the drivers seat when you noticed the problem so I'm wondering if the left side springs are a bit stiffer as opposed to a smidge taller. Nevertheless unless you were parked sideways to an incline then the front (and of course the rear) ends should be even.
I'm betting the installer munged up the left with the right. Where did you get them done?
Good Luck …
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
Navigation System
Burlwood Shifter
Guards+Fenderwell Trim
PIAA16969
Smokers Package
My Car
Old Mar 21, 2001 | 09:29 PM
Jens H.'s Avatar
retired
The springs are not marked left and right but Comptech does want the higher spring rate on the driver's side as most vehicles typically are driven with only the driver in the car.One thing to check is to make certain that the springs are properly seated in the lower spring mount.If they are not mounted correctly it will cause this problem.Take a look at your lower spring perches and you will see that they are not flat plates but are in fact stepped to accept the end of the spring.Make certain that the end of the spring is seated in this step.Also verify that the springs are seated fully in the upper strut mount.You will probably need to jack the car up to see both mounts.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Old Mar 21, 2001 | 10:03 PM
syncivic's Avatar
<font face="Verdana, Arial" size="2">Originally posted by WebToker:
</font>
Mom once said to think before speaking, or in this case, punching keys....Show me a set of CL-S comptech springs labeled left and right. The dealer in this case clearly knows more than you as you haven't measured any stock -S's to discover that there is a ride height variance from right to left.
Old Mar 21, 2001 | 10:21 PM
Al Uminum's Avatar
[quote]<font face="Verdana, Arial" size="2">Originally posted by syncivic:
</font>
and then this drivel...
<font face="Verdana, Arial" size="2">Mom once said to think before speaking, or in this case, punching keys....Show me a set of CL-S comptech springs labeled left and right. The dealer in this case clearly knows more than you as you haven't measured any stock -S's to discover that there is a ride height variance from right to left.
</font>
And I know you didn't listen to anything worthwhile your mom said because only a dumbass wouldn't notice that it wasn't webtoker who said they were labeled but me. So what are you doing typing in the dark, one handed? And I stand corrected already as I said "If I remember correctly" they were labeled. It's been cleared up already so whats your point about your post?
"01" CL Type-S
White\Black
Comptech Springs
Comptech Sways
Navigation System
Burlwood Shifter
PIAA16969
Smokers Package
My Car
[This message has been edited by Al Uminum (edited 03-21-2001).]
Old Mar 21, 2001 | 10:28 PM
Rayan's Avatar
4th Gear
i actually got my measurments by using a clear ruler and used the same points to get acurate measurements. and i did actually go to the back of the dealership (which had probably 50 CL-S's in stock) and measure the heights of 3 CL-S's. on average, they all were about 1/8" lower on the driver's side...but NOT 3/8"! if this can't get resolved i'm going to just go back to stock. i definetely don't like the way it looks. i already ordered the sway bars, and hopefully they will somewhat make-up for the loss in handling if i go back to stock.
Old Mar 21, 2001 | 10:47 PM
JZ's Avatar
JZ
Did you measure it on a flat surface? I know that sounds like a dumb question but I remember thinking the same thing when I got mine installed and it just ended up that I was looking at the car while it sat on very slight inclines. Try taking peeks at the gap on different surfaces. It may just be when the car is on slightly uneven surfaces.
About the spring rates--I would assume that with no one in the car the springs should sit the same and no difference should be observable between the height of the driver's vs. passenger's side. Only when you start adding weight and compressing the springs should a difference be noticeable.
Black/black CLS
Comptech headers, springs, swaybars
Koni yellows
PIAA 19169 road lamps
Solaris Hi beams
Potenza RE730 225/45/17
Red AEM CAI
35% mirror tint next
Feb 25, 2020 09:57 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
k6biv
Sep 22, 2015 02:06 PM
