Comptech Springs + Koni Yellows = Cut Bumpstops? Even rake?
To those with the comptech springs and yellows. .
did you cut your bumpstops, are you even supposed to?
also if you put the rear yellows on the lowest perch and kept the perch for the fronts at its highest setting, would it be even?
if you put the rear on the lowest setting and left the front in the middle setting they'd be even and there is absoultly no reason to trim the bump stops,unless you're looking for an even firmer ride
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
