CompTech Rear Sway Bushing Options: polyurethane vs. hard rubber
boosted is best
Spoke with CompTech yesterday about the squeaking polyurethane bushing issue regarding the CT rear sway bar. Althought the polyurethane bushing provides the best rigidity for performance, it will always be prone to squeak. To address this problem, they are working on an alternative hard rubber bushing that shouldn't have this squeaking issue, but will be a little less rigid with a slight loss of performance.
boosted is best
How long ago did you do this? CompTech said, depending on how you drive, expect to have to reapply teflon tape and/or grease every 3-6 months, cause the tape wears out and the grease gets squished out since bushing is not designed to hold grease.
Originally posted by mr. big
i took my poly- bushings and put lubricant grease inside where it contacts the teflon tape...no squeaks whatsoever
about 3-4 months ago....not a single squeak yet....(knock on wood)
but u kno, it wont be that hard to reapply...just jack the car back up and thats it...prolly 10 mins
k6biv
09-10-2015 06:37 PM
