Comp High Boost Pulley Question
Styl1n
for those of you with the Comptech supercharger with the HBP
what is your fuel pressure with and without the vacum line?
I know that needs to be adjusted when adding this pulley
thanksssss
thanksssss
My fuel pressure gauge usually registers 35-38psi when idling on an 'up-to-temp.' engine. Sometimes it hits 40psi at idle when sitting in traffic with the A/C and associated fans on. At WOT the gauge is buried at 100psi. It's been that way since the install back in Jan 2005.
CLS-6; HBP; 100k miles with 55K on the blower.
Use the Search for 'fuel pressure' and finds tons of info.
THE J35A2...
thanksssss
thanksssss
BoricuaTL
04-08-2016 01:08 PM
wusty23jd
09-24-2015 11:41 AM
NBP_BALLER
09-23-2015 08:18 PM
