Come see the CLS 6 Speed get walked down by the 3.5 6 Speed Maxima
Old 07-25-2007, 12:43 PM
  #121
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
Originally Posted by L's TL
scattered thunderstorms
Thanks.
Old 07-25-2007, 01:23 PM
  #122
JBlueCLS6's Avatar
Originally Posted by CLS6SpeedNupe
all this entertainment before lunch time. You better watch out before that chick JblueCL comes posting and gets you suspened by his/her friends wit benifits moderators.
You're a freaking tool and the vast majority of the board agrees however keep to their own. Have fun asking stupid questions that have already been touched on 1000's of times like "If I buy this $500.00 Turbo Kit willl I be uberfast?"
Why don't you ask yourself "Why is my IQ identical to my age?"
"Why did so many people make negative comments towards me because I lash out like a spoiled 6 year old who's parents didn't buy him that Jolly Rancher or Tonka truck in the store?"
Keep contributing with your worthless threads though that take up storage though and continue to act like an asshat. I'm certain your stay will be shortlived.
Old 07-25-2007, 03:59 PM
  #123
CLS6SpeedNupe's Avatar
DUDE WHO CARES!!!...Go play wit your blown supercharged motor and learn how to shift while you are at it so you wont have that problem again.
Old 07-25-2007, 04:01 PM
  #124
EL19's Avatar
roflmfao at asshat...thats a good one, never heard it b4
Old 07-25-2007, 04:30 PM
  #125
JBlueCLS6's Avatar
If I wasn't shifting right I would have bent valves which is common from over revving. My piston rings were fried from boost.
Old 07-25-2007, 04:31 PM
  #126
JBlueCLS6's Avatar
It just feels slow. Hasnt felt fast since last monday when I spun out bad bounce of the rev limiter a couple times and had a lot of wheel hop causing the check engine light to flash for a few minutes constantly.
And telling me how to learn to shift?
Old 07-25-2007, 04:39 PM
  #127
Pseudomaniac's Avatar
"I would just go buy a bottle of NOS and use that"
"NOS" - It's a brand name.
If you were referring to Nitrous Oxide as an oxidant to allow the vehicle to consume fuel at a more rapid rate, thus producing more power - then I believe you mean "N2O".
If you're having fuel delivery problems as it is, the last thing you should be thinking about is spraying. Blowing the tops off of pistons is a really neat experience - but not something you want to make a habit of on a rather pricey engine to rebuild.
If only it were as easy as just going and purchasing a bottle - maybe more people would do it.
To run Nitrous, you shouldn't even think about a dry shot - which means you're going to get into tapping the fuel line as well. Even with something as friendly to install as the Zex kits; you're talking about 4 good hours of labor if everything goes right. Running lines, installing solenoids, tying into the throttle positioning sensor, installing nozzles, etc.
To have any use out of the bottle, you're also going to need a pair of bottle heaters, and probably a second tank to maintain line pressure.
Not that I have ever done this before or anything....
I mean afterall - apparently you just need to go get a bottle of NOS and you're good to go.
Old 07-25-2007, 04:44 PM
  #128
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,162 Likes on 1,099 Posts
NOS FTW!!!
Old 07-25-2007, 04:45 PM
  #129
Once again you prove your a total idiot that knows jack shit about cars (But then again judging by nearly all your posts you haven't left any doubt). If I wasn't shifting right I would have bent valves which is common from over revving. My piston rings were fried from boost.
A stock Honda block giving up the ghost from boost? That never happens.
Sucks dude - sorry to hear that. At least it's an excuse to build up a 3.5 block with a lower compression setup. Sleeves are nice too - though I shudder to think what it might cost to do ductile sleeves on a J block. The last B block I did was about $1300 + shipping. I'd suggest a set of dished pistons to drop that compression a bit at least.... makes a world of difference in the longevity of the Honda motors when they are pressurized. You running the larger pulley?
I've been thinking about chasing down a comptech blower somewhere - but I don't feel like welding pistons to the block either....
Old 07-25-2007, 04:50 PM
  #130
F23A4's Avatar
Received 1,671 Likes on 932 Posts
MODERATOR'S NOTE: Keep this thread free of insults or I will lock it accordingly.
Old 07-25-2007, 04:52 PM
  #131
JBlueCLS6's Avatar
Exactly CLS6nupe is a moron
I'm already in the process of gathering parts to stroke the motor to a 3.5.... pefect time to build a motor as the Car is down and I have another car to drive around. After I get Forged Rods and lower compression forged pistons I should safely be able to boost 9 pounds tuning with Emanage Ultimate.
I was running the HBP since the day I got it installed.
Old 07-25-2007, 04:56 PM
  #132
Bluecl6, not to hijack the thread, but if you don't mind. Send me a pm cause I have a question about this motor build you are about to do since I just did one. I might be able to get you some aftermarket ARP head studs to go with your motor.
Old 07-25-2007, 04:58 PM
  #133
Note to self....High Boost Pulley + stock J block = baked rings. Got it.
Should be a pretty sweet setup when you get it together - 13 flats with 117-120ish traps - or better than that?
I hate launching heavy, revvy, high horsepower fwd cars.....RWD FTW! lol.
Either way - that's a Maxima killing machine. I bet you'd give an M3 all it could hande up top too.
I've lowered it and done headers/intake so far (03 ClS-6) - but it still doesnt feel as strong from 80+ as I thought it would. How does the boost feel in that range?
Old 07-25-2007, 05:03 PM
  #134
JBlueCLS6's Avatar
Pmd
Old 07-25-2007, 05:08 PM
  #135
JBlueCLS6's Avatar
The Car was running low 13s and near 110 MPH before. More then likely Mid-Low 12s is possible after getting my dampers and Motor mounts installed with the new engine and a new clutch kit which is readily available right now that I'll also be putting on.
Still would pull well in 4th. gear (90ish to 120). With boost 4th. feels like 3rd NA with all the boltons.
Old 07-25-2007, 05:15 PM
  #136
JBlueCLS6's Avatar
BLK2001Tlon19s your PM box is full. Free up some space.
Old 07-25-2007, 05:17 PM
  #137
fixed, my error.
Old 07-26-2007, 09:03 AM
  #138
EL19's Avatar
actually i was responding to ur lil comment about how u thnk i thought octane booster would give me HP and/or torque, and the only thng closely related to that is NOS or if u wanna get technical NO2, which is Nitrous oxide, one part nitrogen two parts oxygen not N2O...i am a chemistry major so plz dont try to school me on chemicals...and for the record i wouldnt ever plan on using nitrous, i dont like it
Old 07-26-2007, 10:00 AM
  #139
It would appear that worse than chemistry than you are at cars....I'm not even going to touch this one.
You're obviously on a budget and wanting to make your car faster. You'll find no bang for the buck better than nitrous - period.
Have you run this car yet so we can put this poor beaten forum to rest?
Old 07-26-2007, 11:14 AM
  #140
EL19's Avatar
lmao i like u...u continually make me laugh! yea im on a budget yet i have every bolt on, unichip, and i will b adding the apexi neo next week..also now that comptech is back up i will become boosted within the next month or so and ive only had this car for a year! funny...yea nitrous is the best bang for ur buck and will shave a good amount of time off the 1/4 but thats not my cup of tea. this forum was never about me in the 1st place it was about sum cunt in a maxima saying he could walk a modded cls6 with a 3 car lenngth advantage in which he never showed up. and i will b running the car tomorrow thnks..ill keep u updated!
Old 07-26-2007, 11:46 AM
  #141
you running him tomorrow?
Old 07-26-2007, 12:10 PM
  #142
EL19's Avatar
who jon?? hell no it would b the same outcome as yalls race...ill race him top end tho just to see wat happens...i thnk i may have a chance
Old 07-26-2007, 12:21 PM
  #143
Go for it.
Old 07-31-2007, 03:28 AM
  #144
I'm a Vagiterian.
All Mine's Avatar
What's the dily-o on this? Did you bitches ever race this bitch? I'll strap by bottle back in and drive up there and run him.
Old 07-31-2007, 03:29 AM
  #145
I'm a Vagiterian.
All Mine's Avatar
What's the dily-o on this? Did you bitches ever race this bitch? I'll strap my bottle back in and drive up there and run him.
Old 07-31-2007, 09:14 AM
  #146
I apprechiate that
Old 07-31-2007, 10:32 AM
  #147
EL19's Avatar
lmao...hey Mo were u there wen i raced Jason?
mlody
12-04-2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Come see the CLS 6 Speed get walked down by the 3.5 6 Speed Maxima
