Coin Tray Help?
BUY MY CL - see garage!
Coin Tray Help?
ok guys, i think i've lost it. the coin tray is over-full, and therefore dropping change into the console on every bump. how do i take it out. the owners manual tells me how to open it, but i can't figure out how to remove it, and there is a bunch of change back there (i can see it on top of the OBD, and i'm really afraid things will start shorting out. ) thanks for any advice
https://acurazine.com/forums/showthread.php?t=165139
I tried to "just pop it out," but stopped before I broke something. I've still got chagne back there.
i had the same problem a week ago. i ended up removing that panel thing that covers the diagnostic port. that gave me easier access to the two loose quarters. it was still tough to get them out. it took me an hour or so.
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Originally Posted by lokijibber
.......how do i take it out. ...... thanks for any advice
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
A clean ride is in
I hear you, I hardly use the "not an ashtray" at all. When I do use it, I make sure to take the little bit of change I have in there when I get out.
Old&CnL
1) It does pop out- you can't break anything important.
2) Go to Acura Carland website, buy the real ashtray- fits better.
3) If you really want your change back, do a seach for console removal. There are some good web site instructions. It's not really that hard.
4) Take up smoking so you won't put coins in there.
C-n-L
C-n-L
C-n-L
C-n-L
thanks guys, i had a feeling it would just be a dig... just shouldn't use the damn thing anyway
Originally Posted by buiyahkah
did all those coins back there cause your "coin tray" to not close all the way? because i have that problem right now, it won't close completely and it's freakin annoying...
Originally Posted by Blackwidow:
what i did was push the coin(s) until they fell below [right under neath the cointray]. Then all u have to do is pull up on the plastic tray underneath the cointray and it pops right out. then u just use some pliers or something to pick up the coins. really easy and straight forward.
mlody
12-04-2019 02:11 PM
09-25-2015 06:14 PM
