Coin tray
Old Mar 31, 2003 | 08:59 PM
shumski15's Avatar
Coin tray
I had some coins fall behind my coin tray and now it won't close all the way. Does anyone know how to remove the coin tray?
Old Mar 31, 2003 | 09:05 PM
chef chris's Avatar
Homeless
I think you just lift up & pull...
not 100% sure tho
Old Mar 31, 2003 | 09:39 PM
shumski15's Avatar
Cool! thnx, I'll try it out tomorrow.
Old Mar 31, 2003 | 09:56 PM
JaySyn77's Avatar
I have this happen to me all the time What you need to do is pull out the "L" shaped cover that's under the coin tray. It's located in-between the Left & Right seat warmers. Once you remove that, you should see the coins that are not allowing the tray to close. You may have to unscrew the screw just a bit to allow the coin to fall down. Dont remove the screw completely cause it may be a mission to put it back.
Old Apr 1, 2003 | 05:03 AM
bullaculla's Avatar
Buy a coin tray for the '03. it has a spring loaded flap on top that holds the coins in place when it is closed. I had the '01 PDG and i also lost a bunch of coins. I just kept hitting the side and slamming it closed.
Old Apr 1, 2003 | 05:15 AM
Klamalama's Avatar
Capo di Tutti Capi
That top flap on my 03 6-speed coin tray decided to separate itself from the vehicle. It may not be a good solution.
Old Apr 1, 2003 | 05:23 AM
bullaculla's Avatar
how did that happen?
you're right tho...
I don't even know if it fits
Old Apr 1, 2003 | 11:41 AM
peiqinglong's Avatar
If your still interested in removing it...look at http://www.bui4ever.com/webpage/projects.htm for Cntr Console Removal.
Old Apr 1, 2003 | 12:33 PM
eclipse23's Avatar
Moderator Alumnus
NO NO NO
SIMPLY TAKE YOUR FIST AND PUNCH THE SIDE OF THE WHOLE CONSOLE HARD. REPEAT A FEW TIMES AND IT WILL CLOSE AGAIN. TRUST ME THIS SHIT HAPPENS TO ME LIKE EVERY OTHER MONTH JUST GIVE IT A GOOD SMASH OR TWO.
Old Apr 1, 2003 | 01:44 PM
fuzzy02CLS's Avatar
The 02's have this flap too. At least my 02 did. I never had any change fall behind, or any other change related issue.
Old Apr 1, 2003 | 02:00 PM
Scrib's Avatar
Administrator Alumnus
I tried to put change in every "coin" drawer we have in our car and nothing worked for me. I ended up stealing a small tupperware container (it's really small), to hold my change.
After having the change fall all the way behind the center console and rattling every time I hit a bump, I had enough. Took me over 1 hour, with a straw and a piece of gum to FISH the fockers out!
Yikes
May 3, 2021 04:29 PM
mlody
Dec 4, 2019 02:11 PM
ROWDY621
Sep 30, 2015 03:20 PM
d.lim
Sep 15, 2015 08:54 PM
