Coilover kit time.. choices within.. please advise
I have H&R Sports right now, and I want to upgrade to a coilover system.
I've looked around, and have come up with two choices.
1. Tein SS
2. Ground Control Coilover w/ damping adjustable shocks, like Koni or Tokico.
Now, the first choice would run about 900 dollars. The second set, I think, would be around... I don't know. 370 for the GC kit, plus 560 for Koni, so 930.
Now my question is, according to the Suspension section, there are two choices of GC Coilover kit. To be used to stock shocks, and to be used with Koni shocks only.
Well, is it possible to use it with any other shocks? What are other more affordable alternatives on shocks? I mean, the whole point of my looking into other kits than the Tein SS is so that I could save money.
Please help. Thank you.
1. Tein SS
i would say just go with the tein ss. its better if you got something that works with each other (spring+shocks)..instead of mix and matching (GC+Koni). from what ive heard using other shocks with the GC will make it bouncy..not sure though..
btw..if you look hard enough you can find the Teins for a good price..something in the range of 850-900
I have never bottomed out with mine. I have them lowered in the summer to the point where you can just get 2 fingers between the fender and the wheel and the stiffness on 12 out of 16.
Atl/Mia reppin'
I know you can get upgraded springs from Tein (stiffer spring rate).
With the GCs, you can mate them to KYBs and Tokicos, you just have to specify that. You can also order custom spring rates as well.
If you have more money, have you thought about Zeals or JIC coilovers? I have Teins on my 1st gen, and love them...just thought I'd give you some other options...
Originally posted by Pure Adrenaline
The thing is, when the shocks wear out on the Tein SS, you have to replace the entire unit. That would suck a lot... not to mention expensive.
///M POWER
1 Post
Originally posted by peiqinglong
Yes u can get upgraded springs, I had them.
Originally posted by darrinb
what do u have to get so your car wont bottom out, is it edfc??, cause these are designed for the accord and its lighter...
The issue with bottoming out has to do with the spring rate. The CL is about 400 lbs heavy than the Accord and the springs that Tein ships with the Accord/CL/TL kit is designed only for the Accord. In drops of up to 2 inch, bottoming out is not an issue. It's when you go lower that you have problems. I was fine at 2 inchs, but when I started going to 2.5...3.0 inchs did I have problems. For most people that is way too low, so they do not need to consider upgrading springs. One draw back to upgrading the springs, in my case because I did 2 kgf spring upgrade, is that that is significantly stiffer than what Tein originally ships; so when the springs settled, it didn't settle much. Previous before, I could go as low as about 3 something inchs. With the upgraded springs, the lowest I could go was 2.7 or so.
i see, can u buy them with the upgraded springs to save $$??
Originally posted by DaveTypeS02
How bout the Apexi WS coilovers
What is a pillow mount, peiqing?
I imagine some of you never heard of what a pillow mount is or what it does. Let me assist you. For the next part fo the informative post of the year by me, we'll discuss pillow mounts. For further reading, you may wish to visit this. But for a basic run down. Your car has pillow mounts. It comes stock. When you use springs, you'll basically be reusing your stock pillow mounts. This is also true if you are using the Tein S/S kit also. So what about all the other kits with upgraded pillow mounts you ask? Well there are two types of pillow mounts. We'll discuss the first one first . The first type is just your ordinary big chunk of aluminum or whatever metal they wish to use to make it. By having an aftermarket one that is thicker than your stock one, it allows for better steering response because the springs can't "dig" so much into the thicker ones as it can in the flimsy little stock one. This is also makes the ride stiffer also. The second type of pillow mount is the adjustable camber pillow mount. This does away with the need for camber kits because camber adjustments are done straight from top. And usually with the camber adjustments being up there, it's easier to get closer if not at stock numbers.
The picture shown below is a comparasion between the NEX kit (left) and the Tein S/S kit (right). This picture shows two things, the difference in the upper pillow mount and why the NEX can never be set to stock height and why the NEX can go lower than the Tein can.
![](http://www.bui4ever.com/albums/my_car/aaa.sized.jpg)
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
4drviper
09-23-2015 07:42 PM
