clutch slipping between gear changes but not when in gear?
well here we go again the clutch wont slip when its in any gear but when i try to do a fast shift it slips and wont grab till i let off the gas.could it be the flywheel is glazed or the pressure plate etc,i can floor it in 3rd or fourth and it wont slip but when i shift quick it slips??
well i think i know what it is im going to bleed the check valve since are clutch is hydraulic something is not allowing me to shift fast between gears so i think that would be it
The clutch includes a one-way delay orifice (check valve) located in the slave cylinder that restricts return fluid flow during rapid clutch engagement. This restriction of fluid reduces drive train shock and limits the torque load on transmission components. The result is a less abrupt engagement of the clutch during overly aggressive release.
SidhuSaaB
05-30-2020 12:40 AM
