cls vs 05 rsx type s
yesturday i installed my custom test pipes so now i have aem cai, aw headers, cutom test pipes and fuel pressure regulator. so i wanted to try out my car so one of my friends set me up with a rsx with cold air and test pipes. we went of a first gear roll and i had him by a car all the way to 125 mph. b4 i did the work to my car rsx type s used to pull lik 4 cars on me so yea.
Originally Posted by robeaneee
ohhh he was on the bottle...ok you didn't mention that..i don't think a stock rsx-s can take u by that much
I
Originally Posted by type1cl
no he was on motor he has never sprayed on me hes always ran me motor. and when he beat me i was bone stock and he had an aem cai.
Do you have a type S? if so, then you suck at driving. They (RSXs) run 14.7-14.9 stock. 4 cars sounds like you're running low to mid 15s.
Adventurist.
I
first of all yes its type s and i dont suck at driving its automatic nerd second you probably havent raced the new rsx type s which has way more take off then the old one since it has a new final drive and when he beat me by 4 cars i was stock he wasn't and i wanna know what your cls ran stock. you talk like u run 12's .
A CLS should not lose to an RSX by 4 cars, if at all.
What does the final drive have to do with 1/4??? Not sure if you've noticed, but gate shifting helps and you have to know how to launch an automatic too, you can't just floor it.
What does final drive have to do with 1/4 mile you ask?! Just about as much as horsepower and torque!
Just made yourself look like a lil
Changing the final drive in cars has been know to pick up huge gains in the quarter mile. Changing final drive gears in mustangs for example can drop as much as 1/2 second of a quarter mile time without changing anything else.
RSX's are a hell of alot faster than you must think. A local guy just ran 13.5 @ 103 MPH with bolt ons on street tires.
I
Ok, maybe I didn't know that, but that's why I asked. The fastest stock RSX I've seen has run a 14.79. I know with Hondata and bolt ons they can run high 13s, but never heard of anyone running a 13.5. Maybe he could lose to an RSX, but 4 lengths seems to much.
'99 Acura 3.2TL
...so you are saying your buddy with an intake on his RSX-S beat you by 4 car lenghts and you have a CL-S ? sorry but..
i beat one with my dad's 2004 TL... he was definitly slower. and there'S not much difference between 2004 TLs and 2002-2003 Type-S'...
Guys... Just a heads up here... The '05 RSX-S with an intake will run mid 14s. If he (the CL-S) was stock he would easily get beaten by 4 lengths. A stock CL-S runs anywhere from 14.8-15.5 depending on the car and the driver.
The '05 RSX is a whole new animal...
thank you for that steve this guy thinks the rsx is slow or somthing, i also have an integra built ls vtec and im going to swap a itr k20a next.
Now these numbers are from Car & Driver Magazine. Although i trust Motor Trend more because of better and more accurate numbers... So hope fully you can work out the numbers..instead of arguin back and forth
Vehicle type: front-engine, front-wheel-drive, 4-passenger, 3-door coupe
Price as tested: $24,140 (base price: $24,140)
Engine type: DOHC 16-valve inline-4, aluminum block and head, port fuel injection
Displacement: 122 cu in, 1998cc
Power (SAE net): 210 bhp @ 7800 rpm
Torque (SAE net): 143 lb-ft @ 7000 rpm
Transmission: 6-speed manual
Wheelbase: 101.2 in
Length/width/height: 172.4/67.9/54.9 in
Curb weight: 2848 lb
Zero to 60 mph: 6.2 sec
Zero to 100 mph: 16.6 sec
Street start, 5-60 mph: 6.9 sec
Standing 1/4-mile: 14.9 sec @ 95 mph
Top speed (drag limited): 136 mph
Braking, 70-0 mph: 181 ft
Roadholding, 300-ft-dia skidpad: 0.86 g
EPA fuel economy, city driving: 23 mpg
C/D-observed fuel economy: 22 mpg
Wheelbase: 101.2 in
Originally Posted by dukmahsik
new rsx S is definitely faster than the previous models, they have type R gearing
As well as Type R intake manifold, cams, and exhaust. New ECU programming too.
maybe i should get the type r exhaust for my car mr steve ... would i get uber jdm gains llmao cant wait for the kit to get here ! i am getting a custom file written by a local ecu tuner
Registered Big Dog
first off all with the new final drive the rsxs has shorter gears now, meaning its gear racial is now set up more for quarter mile ok and i didnt run him off the hole it was a first gear roll so i dropped it first and we rolled till im about to jump into vtec on first and honked 3 times and then we took off. if you have another way to do it teel me.
i cant believe an rsx-s could pull FOUR cars on a cl-s .... this has happened to no one else in a cl-s....... how bout you check your actuator.. i bet you $20 its broken and you're basically driving a cl-p
Registered Big Dog
Wheelbase: 101.2 in
Wheelbase: 101.2 in
btw this should be in racing
I
No stock CL or TL is gonig to trap at 95 MPH. Sorry guys but the new RSX is clearly quicker.
http://forums.bimmerforums.com/forum...hp?userid=3311
Stock CL-S with just 1200 miles on the car. Guy ran a 14.1 @ 96 mph.
