cls replace front/side mount? or rear too?
Old Apr 18, 2010 | 11:24 PM
AnthraciteTypeS's Avatar
6mt swapped..smart
Well my mounts are shot in my 03 auto cls. I'm about to order the front and side mount, but do I need to replace the rear too? I can't look right now which is why i'm asking. I did a search and saw that most people replace the front and side but was curious why I havn't read much about the rear? Does it not go out that often or something? Thanks in advance for any help.
Old Apr 19, 2010 | 02:18 PM
Mike's Avatar
the only way to really tell is for you to get under there and look/feel around.
it's a pretty good bet that if the other mounts are shot your rear is too.
are you going to buy locally or online? who's doing the install.
Old Apr 19, 2010 | 09:07 PM
RUF87's Avatar
Lead Footed
The rear tends to hold up a bit better, but if your 03CLS has never had them replaced the odds are good that it's bad as well. As Mike said, you'll need to feel around and see if there's any fluid leaking from it. With a flash light you can also look at the top and see if there's anything there.
As to getting them installed, the front and side are pretty easy. The rear on the otherhand is a real pain in the . It requires disconnecting the intake, exhaust, one of the power steering hoses, bypass valve actuator, rear crossmember dampners. I know some don't do all these, but to get the rear mount out you need to jack the motor up pretty high and you risk damaging things. It's not real complex, but real involved . . and a 2nd set of hands is a real help on this one. It's also why it's pretty costly to take it to a dealer.
Anyway, good luck.
Ruf
Old Apr 20, 2010 | 01:40 PM
5thgen's Avatar
Trust Me I'm Better!
Hey Ruf, I'm n Dallas, where would you take it too to get them fixed. Mine are out also. Thanks
Old Apr 20, 2010 | 02:30 PM
6mt swapped..smart
Thanks for the help Ruf. I'm going to be having a mechanic friend do it on the side. I'll be getting the parts from acuraoemparts (unless someone knows a cheaper place). I think I'm just going to do the front and side as the rear looks fine and I don't really want to deal with all the work involved in replacing it.
Old Apr 22, 2010 | 12:08 AM
RUF87's Avatar
Lead Footed
ah, I don't have anyone . . I do most everything myself.
You might want to try posting on the DFW thread and see if anyone has a mechanic in the area. Where exactly are you? Let me know and I'll chew on it and see if I can think of someone. BTW, do you know if all 3 are gone or??
Ruf
mada51589
Jan 9, 2025 04:40 PM
james357
Feb 13, 2016 02:37 PM
wilztlxs
Dec 1, 2015 09:16 AM
Tsov Tom
Sep 6, 2015 07:56 AM
KillerG
Sep 4, 2015 02:02 PM
