CLS 6spd vs. CLS AT (video)
Damn you murdered AJ...
so what are the mods on each?
Both are stock!!! For now!! :whistle: |
kool
So the 6 speed lost?
looking at the video, i believe the 6 speed won.
the loser has foglights :thumbsup:
foglights=not 03 6spd
AJ will eventually learn hopefully no matter if he put the brakes on or not he can't keep up with the 6 spd..
I agree :thumbsup: |
you have to know how to shift in order to win when it is cls vs cls manua and bot are stock... the cls manual has to be launched perfectly and get every shift perfectly to truly beat a cls auto... otherwise they will lose or just be tied....
I caught every gear smoothly and perfectly.. :toocool: |
Originally Posted by goredcar
The rule of thumb is that an auto with headers is bout the same as a stock 6MT.
Originally Posted by Sun Diego CL-S
that's the first time i've seen someone say this but i have always thought about this and wondered if it were true. i see what you mean. but then i would like to see this confirmed time and again. have you seen threads with this or with videos? :sure:
Comptech rates their S/C as +34-40HP with the auto and +54-57HP with the 6MT. Same S/C... I was also snooping around on their site and looking at various dyno charts... and at 6K rpm a stock 5AT makes 208HP, while a stock 6MT makes 220HP. In race conditions the 6 speeds will sometimes not do as well as they should because good launches are very tricky. In the excitement of the moment if you drop the clutch and hit the gas hard, you will break the tires loose and just spin... while the auto leaves you in the dust (with your wheel hop). |
