Clearing Headlight Day 1
Today, I finally decided that I was going to clear my headlights. Everything started off ok, taking off all the bumper stuff was simple. The problem was that after I pried open the headlights, I got a bit impatient and started glopping on the silicon. When I put the 2 pieces together, it didn't perfectly match like the uncleared light. To anyone who has done this, is it supposed to be this way? IF I successfully finish, I will write up a more thorough method of what I did. Also, if you ever do this remember to be patient, because that is what f*cked me over.
pics
The Creator
ummmmmm...... day 1?!??! dood... your nuts. lol... you should be able to clear and put them back together in under an hour.
use my method:
use my method:
Removing Bumper
1. Remove screw in front of each front tire.
2. Remove plastic pins from the underside of bumper.
3. Remover 10MM Bolts from underside of bumper.
4. Remove plastic clips on top of bumper.
5. Remove screws on top of bumper.
6. Unplug foglights.
7. Remove bumper.
Removing Headlights
1. Remove Bumper
2. Remove bolts from the side of the headlight housing.
3. Remove two bolts under the headlight housings.
4. Unplug connections.
5. Remove headlights.
Clear Lights
1. Remove Headlights
2. Place headlights on a wet towel inside of an oven. Heat oven to 225 degrees. (Do not preheat)
3. After 20-25 minutes remove headlights from oven.
4. Seperate headlights by hand starting from the inner corner.
5. Allow to cool for 10 minutes. Using a razor, trim excess silicone from the inside of the lens cover. Do not remove silicone from the black portion of the housing where the sealant channel is, you will be reusing it.
6. Remove thw two screws that hold the chrome housing to the lens cover.
7. You may now pop out the amber reflector by pushing a CLEAN screwdriver or any utensil for that matter through the hole fpr the parking light.
8. Reattach the chrome portion of the housing to the clear lens.
9. Place lens and black housing back in the oven at 225 degrees for 10 minutes. Do not reassemble yet.
10. After the stock sealent has softened remove both pieces from the oven.
11. Add a small, fresh bead of silicon to the sealant channel on the black portion of the headlight housing.
12. Beginning from the outer side of the headlight, reattach the lens portion of the housing to the black portion.
14. Tighten lens to the black housing in each corner using bar clamps.
15. Allow 24 hours for silicone to cure.
16. Cover holes with duct tape. Test for leaks in steamy bathroom.
17. Put back on car.
7. Remove bumper.
Removing Headlights
1. Remove Bumper
Clear Lights
Location: Somewhere between here and there, yet neither.
Originally posted by I am RobG
under an hour is a little excessive it took my 4 hours and i still didn't put them back together right which i'm too lazy to actually do.
i have a 2003 acura cl and i need to find a urathane body kit, but i don't have to origional bumper could you help me, i currently have fiberglass and i hate it !! please help me find a kit or i would like to buy the factory bumpers !! thanks josh e-mail me jcok69@yahoo.com
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
