cleared and painted headlights, a story w/ pictures
Old 10-14-2004, 09:34 PM
mattg's Avatar
i basically used soopas method. no, not
Removing Bumper
1. Remove screw in front of each front tire.
2. Remove plastic pins from the underside of bumper.
3. Remover 10MM Bolts from underside of bumper.
4. Remove plastic clips on top of bumper.
5. Remove screws on top of bumper.
6. Unplug fog lights.
7. Remove bumper.
Removing Headlights
1. Remove Bumper
2. Remove bolts from the side of the headlight housing.
3. Remove two bolts under the headlight housings.
4. Unplug connections.
5. Remove headlights.
Clear Lights
1. Remove Headlights
2. Place headlights on a wet towel inside of an oven. Heat oven to 225 degrees. (Do not preheat)
3. After 20-25 minutes remove headlights from oven.
4. Separate headlights by hand starting from the inner corner.
5. Allow to cool for 10 minutes. Using a razor, trim excess silicone from the inside of the lens cover.
Do not remove silicone from the black portion of the housing where the sealant channel is, you will be reusing it.
6. Remove the two screws that hold the chrome housing to the lens cover.
7. You may now pop out the amber reflector by pushing a CLEAN screwdriver or any utensil for that matter through the hole for the parking light.
8. Reattach the chrome portion of the housing to the clear lens.
9. Place lens and black housing back in the oven at 225 degrees for 10 minutes. Do not reassemble yet.
10. After the stock sealant has softened remove both pieces from the oven.
11. Add a small, fresh bead of silicon to the sealant channel on the black portion of the headlight housing.
12. Beginning from the outer side of the headlight, reattach the lens portion of the housing to the black portion.
14. Tighten lens to the black housing in each corner using bar clamps.
15. Allow 24 hours for silicone to cure.
16. Cover holes with duct tape. Test for leaks in steamy bathroom.
17. Put back on car.
so anyway, let the pics begin.
lights before clearing
naked. looks kind of tough.
the most satisfying part.
i had them masked up so nice. it was going to be part painted and part chrome, but the chrome started to peel up from the tape so i had to tear off all of my hard work. :'(
mixed up some factory ssm paint (basecoat)
loaded the trusty sata jet
finished applying base coat
all clearcoated and finished
bling
1 done, 1 clamped
awaiting transformation
done
money
Old 10-14-2004, 09:37 PM
mclarenf3387's Avatar
Thats hot.
Thats exaclty what I want to do to mine. Damn, I wanted to be the first though
Question. How much was the gun? How big/how much PSI is your compressor?
Old 10-14-2004, 09:38 PM
Meat stick
JaredGMS's Avatar
Old 10-14-2004, 09:39 PM
"You my boi blue!"
01bluecls's Avatar
Much props man for all the hard work!!! THose headlights look awesome...especially nice touch painting them to match the car.
Old 10-14-2004, 09:44 PM
PiMpiN wHITe Cl-S's Avatar
WOW..good job..looks great!
Old 10-14-2004, 09:48 PM
Sweet as Gold
Ant7701's Avatar
hot ass headlights matt!!! All u gotta do in my opinion for the perfect silver CL is get rid of that damn chrome grill boarder
Old 10-14-2004, 09:51 PM
Old 10-14-2004, 10:01 PM
mattg's Avatar
i should have painted it when i did the lights. oh well, i have more paint.
Old 10-14-2004, 10:06 PM
mrsteve's Avatar
Looks awesome Matt. Did you paint the reflector part of the sidemarker bulb or leave it. I can't tell from the pics.
Old 10-14-2004, 10:08 PM
kumar6's Avatar
ummm... i just press gas and go... nice work though... looks phat.
Old 10-14-2004, 10:10 PM
mattg's Avatar
it's all painted except for the hi and low beam reflector. see the base coated and clear coated pics.
mrsteve's Avatar
I already have the '03 headlights in my NBP. I wonder if actually painting them NBP would improve the look.
Old 10-14-2004, 10:16 PM
mattg's Avatar
i paid ~ $400 bucks for it back when i used to paint. you should be able to get a decent gun for a couple hunded bucks, maybe less.
i have a 60 Gal. craftsman compressor. i think it makes 130 psi or so.
Old 10-14-2004, 10:22 PM
I NEED MONEY!
VeeralS05's Avatar
So when do you want to drive to ATL and do mine?
Old 10-14-2004, 10:24 PM
Beware of leakage
Chopsie's Avatar
Matt, that looks GREAT!!
Excellent work, Superb, OMGFAPTHX!!!
Old 10-14-2004, 10:32 PM
car_lost's Avatar
nice work!
Old 10-14-2004, 10:39 PM
///M POWER
darrinb's Avatar
nice work matt, i think it would also look good in a flat black to match the hood
i'm w/ ant on ditching the chrome grill
Old 10-14-2004, 10:52 PM
TQ > MPG
Joe5.0's Avatar
Gee some of those chrome coated bulbs that illuminate amber, that'll look perfect.
The Altima guys have done the body colored headlight thing a bunch too, I think it looks badass.
Old 10-14-2004, 11:34 PM
ASM I.S. Design FTW.
brianlin87's Avatar
great work
Old 10-14-2004, 11:39 PM
THE SILVER BULLET
pimpscls's Avatar
that is awesome man,i wish i had the balls to do that myself im scared ill scratch soemthing
Old 10-15-2004, 12:37 AM
SocaliCLS's Avatar
Sexy~!!!
Old 10-15-2004, 01:31 AM
TranceFusion's Avatar
very nice! great job!
Old 10-15-2004, 01:50 AM
bluelegend's Avatar
i had that done on my blue cl...i had never seen it on any other cl until this one
Old 10-15-2004, 01:59 AM
robeaneee's Avatar
you had your headlight housings painted ABP? you got any pics? i would like to see that. its like the tl-s a-spec correct?
Old 10-15-2004, 02:27 AM
KavexTrax's Avatar
nice step by step procedures! I need to replace my housing too so this thread is perfect.
btw chrome painted housings are teh new sickness mattg.
Old 10-15-2004, 05:34 AM
VTECPOWER's Avatar
sick...nice work!
Old 10-15-2004, 08:27 AM
If He Dies...He Dies
MisterMehoff's Avatar
LiQice and I have the entire framing painted flat black...including the turn signal reflector bowls. I think the blacked out turned signals adds uniqueness and uniformity to the whole blacked out headlight.
Mine
LiQice
Old 10-15-2004, 08:58 AM
Smitty's Avatar
no way, that chrome grille matches the Center 'A'... I switched my painted one for a chrome one.
... nice job Mattg.... I will send you mine next..
Old 10-15-2004, 09:05 AM
Smitty's Avatar
I recommend you take that orange bulb out and get yourself this one..
http://www.cardomain.com/item/APC504129B
Old 10-15-2004, 09:37 AM
Linner's Avatar
SICK gotta love the DIY mods
Old 10-15-2004, 09:41 AM
Chaptorial's Avatar
That looks awesome matt.
Nice job man.
Old 10-15-2004, 10:50 AM
gingerbread's Avatar
looks awesome matt. i think someone should try using a little spray tint on their headlights. might look sick.
Old 10-15-2004, 01:55 PM
mattg's Avatar
how much did you pay for the trim ring, Smitty?
Old 10-15-2004, 02:06 PM
My Home Planet
joeshmoe's Avatar
That looks really nice.
Old 10-15-2004, 03:12 PM
Jonesi's Avatar
I love stories with pictures..
Looks awesome Matt...!!
Old 10-15-2004, 03:13 PM
Smitty's Avatar
Honestly I can not remember.. I think ShawnS sold it to me when he got his GOLD package.
Old 10-15-2004, 03:31 PM
niz181's Avatar
those are nice
Old 10-15-2004, 03:41 PM
I keeps it real
GoDucksCLSPride's Avatar
Looks great Matt
Old 10-15-2004, 03:43 PM
GoldieAlek's Avatar
damn thats a lot of phuckign work... looks hot!
Old 10-15-2004, 08:21 PM
klepto's Avatar
just saw your post on OT, looks good
Quick Reply: cleared and painted headlights, a story w/ pictures
