Check engine light is on.... dont know whats wrong.
///M POWER
1 Post
on my way back from school today all the sudden my car stated to rev really weird, the check engine light and vsa light both came on. the car wasnt shifting hard so i dont think its the transmission. so i went to the dealer to get it checked out, the service advisor that i always go to tells me that they are too busy and cant take any more cars in
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
u guys think it could possibly be the trannyt or the tensior recall i got in the mail???
thanks
darrin
Originally posted by darrinb
d5 is not flashing, i have reverse
will the dealer fix the 02 sensor
OR... are you guys spraying some gook on the sensor (like liquid wrench or whatever) and damaging it?
Unplug your battary for a little while and see what happens. My check engine lite came right back on after the first drive, I just order a new O2 sensor. My car seems to be okay until you stop then it starts to rev very funny. I should have saved my money for a Comptech header.
///M POWER
1 Post
where can i get a new o2 sensor from??
acura import parts - Acura Carland in GA... good prices!
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Dont let the name fool ya
Don't think it's the O2. typically anytime both lights come on, it is the tranny. Hard shift or not. Especially if the fluid smells burnt. Yes the cel can come on if the sensor is fubar, but the vsa light doesn't. Remember, the vsa stands for vehicle stability assist. O2 sensors do not affect that light. I'd like to know what the dealer says when you can get it checked.
Lone Star Rider
[QUOTE]Originally posted by Stumpy
[B]Don't think it's the O2. typically anytime both lights come on, it is the tranny. Hard shift or not. Especially if the fluid smells burnt.............
Yep, especialy here in Houston!
:P
:P
Sweet as Gold
Its the IAC...idle air control valve...I'm like 99% positive on that. It's stafe to drive but at idle it will surge badly and may even stall. It will do the same thing if the car is low on coolant...hope this helps
Originally posted by Scrib
It'll have a smell to it if it's burnt...
Do you have reverse??? When on of my trannys crapped out on me, I lost reverse. Is D5 flashing???
I have a 2003 cl-s6... 15000km... and the check engine is always on. It stops sometimes and then... I'm okay not even for a day and it lights up again.
I'll go to the dealer soon to have it checked out... but it's been doing that since I have like 6000ks on it and the car drives fine.
Sweet as Gold
Originally posted by allmotor_2000
Umm.. no! I have my IAC disconnected (although plugged in) and it only throws a code every now and then.... its nothing to do with the tranny - although someone confirm this for the A/T.
My Member is Registered
Nobody asked if the car is running different... If the O2 sensor is bad, should it run sluggish?? Should'nt the mileage be through the roof? I had an O2 go on my old civic and it definitely made a difference.
With all the different opinions, I will definitely be interested in hearing the diag. It could be none of the above or all of the above. All of this is speculation. Ant, Jens, and myself all work for dealership service depts, so all of us are going to guess at this point. And the last time I had an IAC go bad on an MDX, the cel and vtm-4 lights were on. Didn't think they had vsa.
'Big Daddy Diggler'
rondog doesnt have problems when driving the car though, he has some rough idling issues. With the car revving weird were you stopped, if you were stopped it could be the 02 sensor. But if you are driving and it is revving funny then it is the tranny no doubt. Its funny because i have the obx and my 02 sensor is in a totally different spot than rondog's which is weird.
Administrator Alumnus
Hasn't this happened to you before Darrin? You posted that your car was acting weird, dash is lit up like a Christmas tree and then it seemed to cure itself?
Or should I lay off the
and stop making things up???
![Bandito](https://acurazine.com/forums/images/smilies/bandito.gif)
Former Sponsor
just get bthe code checked at autozone or something. the vsa, ! and check engine all go on and the dealer said it was from the o2 sensor. I took a lok and the o2 was almost touching the oil pan. all 3 lights come on and off and I hjave rough idle at a stop. otherwise ther are no other symptoms that I know of. if you are worried about future probs with the dealer, than check it somewere trustworthy. if not just let them tell you iot's the o2sensor. youi really have nothing to lose...
