Center armrest - How to replace the padding?
CLS 6MT Navi
03 6MT - My center armrest is flat. no padding left. I removed the whole top with the mechanism attached. and have been removing lots of screws. but the leather top is not loose. How is it attached to the plastic shell?
My leather is ok but the padding needs to be replaced. How to remove the leather part?
I did a search but only found how to remove the entire console.
thanks.
thanks.
Here it is. It is on the TL forum:
https://acurazine.com/forums/3g-tl-2004-2008-93/re-cushioning-flaccid-armrest-639974/
CLS 6MT Navi
thanks, I figured it out. I probably need new leather now too, it is glued to the plastic shell and removing the leather causes it to crease and mark, I guess since it is old. The padding is just a thin layer of gray foam.
Back to a MT!
I replaced my foam with about 1/4" of a heavy density neoprene pad. I stretched the leather as best as I could and then screwed it all back together. If you really look at it you can tell the edges aren't as tight as stock, but it looks good and my right elbow is thanking me! I tried a single layer of the pad and it looked strange and had a stretched leather look. When I added in the second layer it looked fine.
01 Type-S, Sexy Silver
I had a small upholstery shop re-cover the armrest and add some filler foam underneath. its held up very well for 3 years so far. Best $25 I've spent. And it actually matches the interior better than OEM did.
Oakes
Wash & Wax
10-12-2015 11:17 AM
asahrts
09-04-2015 05:55 PM
