CEL misfire codes
Old Jan 11, 2008 | 12:02 PM
RKeatF1's Avatar
CEL misfire codes
Ok here I go again.
This time it is my sons 3.2 cl.
He has misfire codes on all cylinders.
I checked all vacume hoses.
We "seafoamed' the engine 3 weeks ago.
Changed the plugs.
Put in NGK Iridium plugs.
Cleared the codes.
Now they are back.
Any ideas?
ECU?
Coils?
What would be the moest cost effective way to trouble shoot this?
Thanks as always for ideas.
Old Jan 11, 2008 | 12:09 PM
nbennettksu's Avatar
i heart latin chicks
I get the same crap. The codes come and go. Let him go through a full drive cycle and the codes will probably clear themselves.
Old Jan 11, 2008 | 02:02 PM
LukeaTron's Avatar
Hows the car running? Is it noticeably missing?
Old Jan 11, 2008 | 02:39 PM
RKeatF1's Avatar
CEl misfire
No it runs OK no noticible miss
Old Jan 11, 2008 | 05:17 PM
matt21484's Avatar
I had the same problem w/ my 3.2 CLS after I changed my spark plugs. The problem lasted for about a month, where the CEL would come on w/ several misfire codes. I could tell that everything was firing as it should and cleared the codes. The CEL would be off for about a week and then go off again 3 days later on its own.
Like I said, this happened for about a month straight (December 07). As of now it has been off since xmas and no problems.
As a side note, sometimes I noticed that when I would fill up w/ quality gas it would go off on its own when compared to some crap gas. Try that, no guarantees, but it worked for me oddly enough.
Old Jan 12, 2008 | 07:33 AM
RKeatF1's Avatar
It had the misfire code prio9r to the plug change.I cleared them and changed the plugs now they are back.
Like I said we "used seafoam prior to the plug change, also an can of injector cleaner. I am thinking next is to disconnect the battery, to reset the ecu and see what happens.
Old Jan 12, 2008 | 10:02 AM
Paclark01's Avatar
From my past experience the type of fuel used goes a long way. Try using a full tank of Chevron or Shell brand gas. In addition, pick up a can of BG44K for about $30.00, pour it in the tank during the fill up. It sounds as though your fuel system needs to be cleaned.
I personally follow this process 3 times a year, and have not experienced a misfire.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
hrothgar02
Sep 28, 2015 11:08 AM
