Catalytic converter
Old Mar 21, 2012 | 08:54 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
Catalytic converter
Hey guys, so I'm going to finally throw my exhaust on at the end of the month and I need to replace my cat as well. For what I have would a test pipe be to loud or drony? How would a high flow one sound in your opinion?
I'm trying to keep it as cheap as possible because I'm a broke ass student so please keep that in mind.
and my setup so far is XS headers and greddy evo 2 catback.
Old Mar 21, 2012 | 09:33 PM
p.diddy's Avatar
high flow cat= better flow and and makes exhaust a little louder
test pipe= even better flow and makes the exhaust even louder than hfc and it also makes the inside of your car smell like gas.
i personally would never buy a test pipe because of the gas fumes.
Old Mar 21, 2012 | 10:28 PM
rush's Avatar
03 acura cl type s
I've never had a prop with fumes w/o a cat only way you'll
Get fumes is if that's gaskets are blown but then you'll hear the leak
Old Mar 21, 2012 | 10:49 PM
Karanx7's Avatar
Unregistered Member
Grammar. Do you know it?
Don't get a test pipe, because it will make your exhaust sound raspy. I would go with a HFC if you must replace your OEM one. Even a HFC will make your exhaust sound a little more raspy, but nowhere near as bad as a test pipe. Plus, you won't pass emissions with a test pipe.
Old Mar 21, 2012 | 11:47 PM
rush's Avatar
03 acura cl type s
Hahaaaaa that's siri for you . But you get the PIONT.
Old Mar 22, 2012 | 07:13 AM
gnuts's Avatar
3.5 psi
your best bet is to get a magnaflow high flow cat. Although i barely passed emissions with it on...not sure if you have those tests in Alberta. Have your shop weld flanges on it so it can be a direct fit.
Old Mar 22, 2012 | 10:36 AM
Excelerate's Avatar
Former Sponsor
A high flow cat, if designed properly, will make virtually as much power as a test pipe. It will also cut down on some of the drone and rasp. We offer a high flow cat for the 2G CL/TL.
http://store.excelerateperformance.c.../i-494447.aspx
Old Mar 22, 2012 | 03:18 PM
poisx7's Avatar
^^^but it also makes it louder
Old Mar 22, 2012 | 03:33 PM
brian6speed's Avatar
Lone Wolf
I have had the xlr8 hfc and test pipe both installed. I never had any fumes in the cabin issue with either one. My cat droned at 2k rpm but it isnt the latest version I believe. My test pipe I don't notice the drone as much. I could have possibly had an exhaust leak before tho. The sound is still really quiet from my perspective.
Old Mar 23, 2012 | 08:00 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
doesn't a test tube make our motors lose low end a bit?? vs high flow should make it so u barely lose low end and then gain up top end?
Old Mar 24, 2012 | 04:19 AM
aznboi2424's Avatar
If it does make it a free-er flowing exhaust then you'll lose some low end. That's why you don't put a 3 inch exhaust on a NA car.
Aug 15, 2019 12:58 PM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
Rcelestino93
Sep 23, 2015 10:01 PM
jpm3071
NY/NJ
Sep 7, 2015 08:25 AM
