Car is running soooo smooth...
Adventurist.
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
(After a dreaded long day at work & almost 15K on the odo....)
After an oil change of course! Mobil1 5W-30 + Wix filter + oil extractor = happiness. Quick 15:15 minutes (I used a stopwatch
![](http://niteqwill.phytte.com/images/oil1.JPG)
![](http://niteqwill.phytte.com/images/oil2.JPG)
![](http://niteqwill.phytte.com/images/oil3.JPG)
![](http://niteqwill.phytte.com/images/oil4.JPG)
Can you tell me where i can get one of those pump thingys?
Originally Posted by mr5parkle
question: after you pump out all the oil, does it suck out all the oil to the point where you take off the filter and no oil comes out? or do you still have to go under and put like an oil catcher and then change it to prevent drips on the floor?
^ wrong thread.
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
^ that looks so awesome w/ the s/c and intercooler. ![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
when are you going to dyno it or take it back to the strip?
01 3.2 CL-s
how much easier could it get to change your oil with this thing...
question, is there really any advantage to using this pump over draining the fluid out like normal?
Dragging knees in
Either way, I still do it the old fashioned way.
As for the filter change, I always use a plastic bag to cover the filter before turning it loose. It catches all the oil pouring out of the filter. Just make sure you don't pull a dumbass move like me and forget to check for holes in the bag.
On a side note, I think the GM K-series trucks are the worst to do a filter change on. The damn filter is like built into the oil pan, and there's like maybe an inch of space between them. The first time I did an oil change on my dad's car, I backed it straight out of the garage, blocking the driveway perpendicularly... When I realized that I couldn't get a good grip on the filter, I also realized that both of my cars were blocked in and I couldn't go to the store to buy a filter wrench. So after cussing up a storm, I drove a nail into the filter and turned it little by little. Oil was dripping everywhere all over me, and it took like 10 turns to get it off. Ahhhhhh!! I hate GM.
![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
because it pulls the oil thru a straw.
so it takes a little while.
and it doesn't pull the oil out of the filter.
but it is much cleaner.
i take the whole canister to pep boys to get recycyled.
and you can walk away while it sucks out the oil.
and u don't have take out the oil drain bolt.
Adventurist.
Meat stick
Originally Posted by allmotor_2000
Whoa... never heard of this... does it get all the oil out?
I know you are not one, but that was a
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
except for the oil filter, it sucks the motor dry.
it also worked very well on my tranny oil change.
Bleed Honda Blue
go tony!!! even tho i don't know who he is.
Im getting the Tempo Oil Extractor (Oil Boy), but I remember reading that you needed longer hose to reach the bottom of the engine...does it come with it? Or do you need to buy any more additional hoses. Thanks
Do you need a special wrench to get the oil filter out? I never done this in my life so i dont know much about chanching oil. I read that never screw the filter too tight...is that true? Basically, can anyone give me a quick instruction on replacing the filter....I have a WIX filter ready to be installed!
Adventurist.
Also, put a film of oil on the filter's rubber gasket.
Blown is Best
Originally Posted by sgmotoring
I am not sure when and where I am going to get my car dyno tune. I am still looking for a dyno shop that is familiar with emanage. Joseph_99tl I used that on my trans but I will still remove the drain plugs to clean the magnet on the drain bolt every other trans fluid change.
Back to Four Doors
Originally Posted by Bacardi
Thats cool,got to get an Oil Extractor.
Bleed Honda Blue
Originally Posted by Allout
When you pull the plug, does more oil drain out? If so, how much?
ASM I.S. Design FTW.
Originally Posted by Baylove
i'd rather take mine to the dealership, they're the best using genuine honda materials
you can buy genuine honda oil/filters and not have to pay for "honda" labor. heck, there are better things out there than just "genuine" oem honda parts.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I NEED MONEY!
Adventurist.
Originally Posted by Darkness
Acura recommends 5W-20 Motor Oil, but being that I live in South Florida where it rarely get's below 60 degrees, should I take their advice?
Go synthetic, a true synthetic works best.
3 the Hard Way
Or you can opt for more protection and get a thicker oil. Really up to you.
